WMS Server: Filtering Raster/Vector data based on request
params
Gerard Troost
gerard.troost at SOVON.NL
Mon Oct 8 19:51:07 EDT 2007
Hi Jeremy
I'am not sure if i understand you right but if i do then:
in mapserver you can filter your WMS request on the fly like this:
...REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&COUNTRYFILTER=HOLLAN
D
and then in your mapfile:
DATA "the_geom from (select id as oid, * from country where name=%
countryfilter%) as foo"
Regards,
Gerard Troost
SOVON Vogelonderzoek Nederland
Van: UMN MapServer Users List namens Jeremy Nix
Verzonden: di 4-9-2007 20:46
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: [UMN_MAPSERVER-USERS] WMS Server: Filtering Raster/Vector
data based on request params
Is it possible to submit a GetMap request that performs a filtering
mechanism on the fly? In Geoserver, it is possible to pass an
additional parameter "FILTER" that accepts an OGC formatted filter
string where it is feasible to do commands like "PropertyIsEqualTo". I
have a large shapefile that I built using the MosaicIndexBuilder from
the Geoserver project. The image files that make up this shapefile are
not uniform in size, density, or color model. These images have
surrounding borders and legends that will overlap other images. If we
were dealing with only a handful of images I would set up the individual
files separately as different layers. As it is, we have over 100K
images that fit this profile, so we've opted to go with the shapefile
solution. As the images have been named using specific naming
conventions, we wanted to see if we could pass a request parameter to do
something like this:
FILTER=<ogc:Filter><ogc:PropertyIsEqualTo><ogc:PropertyName>location</og
c:PropertyName><ogc:Literal>FILENAME</ogc:Literal></ogc:PropertyIsEqualTo
></ogc:Filter>
Is this possible. If not, does anyone have a suggestion on how I can
implement this. I was worried about the negative performance that would
most likely be involved with have a map file that consisted of 100K+
layers for all of our image files.
Thanks in advance for any help.
__________________________________
Jeremy Nix
Senior Application Developer
Southwest Financial Services, Ltd.
(513) 621-6699
