WFS and large postgis datasets
Christopher Condit
condit at SDSC.EDU
Wed Oct 10 17:46:59 EDT 2007
I have a few questions regarding WFS and large PostGIS databases (mapfile below):
*) When I run a getFeature request on my layer, I get the following GML:
<wfs:FeatureCollection xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd http://mapserver.gis.umn.edu/mapserver http://localhost/cgi-bin/mapserv.exe?map=test/testWFS.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=test&OUTPUTFORMAT=XMLSCHEMA">
<gml:boundedBy>
<gml:null>missing</gml:null>
</gml:boundedBy>
</wfs:FeatureCollection>
However, if I connect with uDig, I do see features returned. Why do I not see the XML when I request it from my browser?
*) Also, I've tried using FE to filter down the dataset with no luck. In this case, since the dataset has millions of features, I'm curious how the FE logic works. Will it attempt to retrieve the entire dataset and only then apply the filter? Or will it apply the filter in SQL. Likewise with the wfs_maxfeatures metadata - will that only apply after it loads the dataset or does it add a "limit" clause to the sql query?
Thanks,
-Chris
NAME testWFSService
STATUS ON
SIZE 800 600
EXTENT -180 -90 180 90
UNITS DD
IMAGECOLOR 255 255 255
WEB
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms4w/tmp/"
METADATA
"wfs_title" "Test" ## REQUIRED
"wfs_maxfeatures" "4000"
"wfs_request_method" "get"
"wfs_extent" "-180 -90 180 90"
# "wfs_onlineresource" "http://localhost/cgi-bin/mapserv.exe?" ## Recommended
"wfs_srs" "EPSG:4326" ## Recommended
# "ows_schemas_location" "http://ogc.dmsolutions.ca" ## Optional
END
END
PROJECTION
"init=epsg:4236"
END
LAYER
NAME test
METADATA
"wfs_title" "test" ## REQUIRED
"gml_featureid" "oid" ## REQUIRED
"wfs_featureid" "oid" ## REQUIRED
"gml_include_items" "all" ## Optional (serves all attributes for layer)
END
PROJECTION
"init=epsg:4236"
END
TYPE POINT
STATUS DEFAULT
CONNECTIONTYPE POSTGIS
CONNECTION "host=myhost dbname=test user=test password=pass port=5432"
DATA "geom from mytable using unique oid using SRID=4326"
DUMP TRUE ## REQUIRED
CLASS
METADATA
END
STYLE
ANGLE 360
OUTLINECOLOR 255 0 0
COLOR 255 0 0
SYMBOL 0
WIDTH 4
END
END
END # Layer
END # Map File
