Mapserver 5 with Oracle10g or ArcSDE 9.2
José Ramón López
joseramonlopez at GMAIL.COM
Thu Oct 11 06:11:56 EDT 2007
Hi list again.
Im trying to configure a new server with mapserver 5.0 connect it with
Oracle 10g or ArcSDE 9.2 , ussing the ms4w package (MS4W PHP5 Base Installer
v2.2.6 )
I have done all that i have read in the instructions.
The problems is that mapserver sends to me a blank image, and with some
clients it send me a error.
I have installed in that machine Oracle 10g client.
This is the configuration of the layer.
LAYER
NAME AFOROS
GROUP "Redes.Ctrl"
TYPE POINT
CONNECTIONTYPE oraclespatial
CONNECTION 'user/pass at SDE'
DATA 'SHAPE FROM AFOROS USING UNIQUE OBJECTID'
DUMP TRUE
DEBUG ON
PROCESSING "CLOSE_CONNECTION=DEFER"
TRANSPARENCY 0
PROJECTION
"init=EPSG:23030"
END
CLASS
STYLE
SYMBOL "circle"
SIZE 10
COLOR 255 85 0
END
NAME 'Aforos'
END
METADATA
"wms_title" "Aforos"
"wms_group_title" "Redes de Control"
"wms_keywordlist" "WMS Aforos"
"wms_srs" "EPSG:23030"
"wms_extent" "154590 4062740 579080 4300000"
END
END
In httpd.conf i have declared the system varibles:
#Oracle Spatial
SetEnv PATH "C:/oracle10gclient/bin"
SetEnv TNS_ADMIN "C:/oracle10gclient/network/admin"
SetEnv ORACLE_SID "SDE91 SDE92 GLOBAL"
SetEnv ORACLE_BASE "C:/oracle10gclient"
SetEnv LD_LIBRARY_PATH "C:/oracle10gclient/lib"
And the file C:/oracle10gclient/network/admin/tns_admin.ora
SDE =
(DESCRIPTION =
(ADDRESS_LIST =
(ADDRESS = (PROTOCOL = TCP)(HOST = 172.19.132.93)(PORT = 1521))
(CONNECT_DATA =
(SERVICE_NAME = SDE)
In the access.log nothing appears about the getmap and layer request , only
the getcapabilites, the same happens in the ms_error.txt
In access.log
[11/Oct/2007:11:58:58 +0200] "GET
/cgi-bin/wms?REQUEST=GetCapabilities&SERVICE=WMS&&EXCEPTIONS=XML HTTP/1.1"
200 5789
127.0.0.1 - - [11/Oct/2007:11:58:59 +0200] "GET
/cgi-bin/wms?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=
1.1.1&EXCEPTIONS=XML HTTP/1.1" 200 5789
and in the ms_error file:
[Thu Oct 11 12:04:26 2007].828000 loadParams() QUERY_STRING:
[Thu Oct 11 12:04:26 2007].875000 msLoadMap(): 0.047s
[Thu Oct 11 12:04:26 2007].875000 CGI Request 1 on process 2288
[Thu Oct 11 12:04:27 2007].62000 loadParams() QUERY_STRING:
REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1&EXCEPTIONS=XML
[Thu Oct 11 12:04:27 2007].93000 msLoadMap(): 0.031s
[Thu Oct 11 12:04:27 2007].93000 CGI Request 1 on process 532
I tried to make the request through explorer like
http://localhost/cgi-bin/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GETMAP&LAYERS=AFOROS&SRS=EPSG:23030&BBOX=154590.0,4062740.0,579080.0,4300000.0&WIDTH=861&HEIGHT=482&FORMAT=image/png&STYLES=default&TRANSPARENT=TRUE
but sends to me a blank image.
Thats anybody knows what is happening?
Thxs and sorry for my english
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071011/df8cf925/attachment.html
