Error on adding EPSG code
Richard Greenwood
richard.greenwood at GMAIL.COM
Thu Oct 11 07:34:20 EDT 2007
On 9/28/07, Mark de Blois <mdeblois at maplecroft.net> wrote:
> Hi there,
> I Am trying to add an EPSG code for Winkel Triple to my MapServer proj
> file but I keep getting the error:
> msProcessProjection(): Projection library error. no options found in
> 'init' file
> I added the entry:
> # Winkel Triple
> <1234567> +proj=wintri +lat_1=45 +x_0=0 +y_0=0 +ellps=WGS84 +datum=WGS84
> +units=m +no_defs <>
> to the file epsg (located at /usr/share/proj on my Ubuntu machine) and
> rebooted.
> Ogrinfo tells me the following about the shapefile I am trying to serve:
> Extent: (-16707480.310734, -10018754.171395) - (16920780.652974,
> 9320947.177797)
> Layer SRS WKT:
> PROJCS["World_Winkel_Tripel_NGS",
> GEOGCS["GCS_WGS_1984",
> DATUM["WGS_1984",
> SPHEROID["WGS_1984",6378137.0,298.257223563]],
> PRIMEM["Greenwich",0.0],
> UNIT["Degree",0.0174532925199433]],
> PROJECTION["Winkel_Tripel"],
> PARAMETER["False_Easting",0.0],
> PARAMETER["False_Northing",0.0],
> PARAMETER["Central_Meridian",0.0],
> PARAMETER["Standard_Parallel_1",45.0],
> UNIT["Meter",1.0]]
> In the mapfile I am referencing this shapefile through:
> LAYER
> NAME 'WTCountries'
> DATA 'maplecroft_countries_winkel_45'
> STATUS off
> TYPE Polygon
> METADATA
> WMS_SRS 'epsg:1234567'
> WMS_TITLE 'Countries_WT'
> WMS_FEATURE_INFO_MIME_TYPE 'text/html'
> END #METADATA
> PROJECTION
> 'init=epsg:1234567'
> END
> Does anyone have any idea what I am doing wrong? Your help would be
> greatly appreciated!
> cheers,
> Mark de Blois
> Maplecroft
Sounds like it is having trouble finding, or reading, your epsg file.
1. In your map file you can explicitly poit to your epsg file with:
CONFIG PROJ_LIB " /usr/share/proj /"
2. You can put a coordinate system definition in a map file without an
epsg code like:
PROJECTION # wyoming west NAD83
"proj=tmerc"
"ellps=GRS80"
"to_meter=0.3048006096012192"
"lon_0=-110.0833333333"
"lat_0=40.5"
"x_0=800000"
"y_0=100000"
"k=0.9999375"
"no_defs"
END
Using your values of course!
Rich
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
