ESRI Personal GDB / OGR not working
Flavio Hendry
flavio at TYDAC.CH
Mon Oct 15 10:50:05 EDT 2007
Hi all [hello Frank, me again]
No way to get something displayed and everything should be correct (same
layer as MapInfo file in same MapFile with same settings works, means
parcels drawn as it should, mdb creates blank image); any idea ??? (mdb
is ESRI ArcGIS 9.1).
LAYER
NAME "Parcelle"
TYPE POLYGON
STATUS ON
CONNECTIONTYPE ogr
CONNECTION "cademonti.mdb"
DATA "parcelle"
SIZEUNITS inches
CLASS
NAME "Parcelle"
STYLE
COLOR -1 -1 -1
OUTLINECOLOR 0 0 0
SYMBOL 'continue'
SIZE 10
END
END
PROJECTION
"init=world:CH1903"
END
END
shp2img and ogrinfo say as well all OK:
OGRINFO:
INFO: Open of `data/cademonti.mdb'
using driver `PGeo' successful.
Layer name: parcelle
Geometry: Unknown (any)
Feature Count: 506
Extent: (715889.010000, 110427.013000) - (719144.278000, 112312.140000)
Layer SRS WKT:
PROJCS["CH1903_LV03",
GEOGCS["GCS_CH1903",
DATUM["CH1903",
SPHEROID["Bessel_1841",6377397.155,299.1528128]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Hotine_Oblique_Mercator"],
PARAMETER["False_Easting",600000.0],
PARAMETER["False_Northing",200000.0],
PARAMETER["Scale_Factor",1.0],
PARAMETER["Azimuth",90.0],
PARAMETER["Longitude_Of_Center",7.439583333333333],
PARAMETER["Latitude_Of_Center",46.95240555555556],
PARAMETER["rectified_grid_angle",90],
UNIT["Meter",1.0]]
Numero_Parcella: String (10.0)
OBJECTID: Integer (10.0)
SHAPE_Length: Real (0.0)
SHAPE_Area: Real (0.0)
SHP2IMG (result is empty image):
[Mon Oct 15 16:34:11 2007].46000 msOGRFileOpen(cademonti.mdb)...
[Mon Oct 15 16:34:11 2007].46000 OGROPen(f:/temp/data/cademonti.mdb)
[Mon Oct 15 16:34:11 2007].78000 msOGRLayerClose(cademonti.mdb).
msOGRFileClose(f:/temp/data/cademonti.mdb,0).
[Mon Oct 15 16:34:11 2007].125000 msDrawMap(): Layer 1 (Edifici), 0.079s
[Mon Oct 15 16:34:11 2007].125000 msOGRFileOpen(cademonti.mdb)...
[Mon Oct 15 16:34:11 2007].125000 OGROPen(f:/temp/data/cademonti.mdb)
[Mon Oct 15 16:34:11 2007].156000 msOGRLayerClose(cademonti.mdb).
msOGRFileClose(f:/temp/data/cademonti.mdb,1).
[Mon Oct 15 16:34:11 2007].203000 msDrawMap(): Layer 2 (Parcelle), 0.078s
[Mon Oct 15 16:34:11 2007].203000 msOGRFileOpen(cademonti.mdb)...
[Mon Oct 15 16:34:11 2007].203000 OGROPen(f:/temp/data/cademonti.mdb)
[Mon Oct 15 16:34:11 2007].234000 msOGRLayerClose(cademonti.mdb).
[Mon Oct 15 16:34:11 2007].281000 msDrawMap(): Layer 4 (Parcelle - Scala
grande)
, 0.078s
[Mon Oct 15 16:34:11 2007].281000 msDrawMap(): Drawing Label Cache, 0.000s
[Mon Oct 15 16:34:11 2007].281000 msDrawMap() total time: 0.235s
[Mon Oct 15 16:34:11 2007].312000 msFreeMap(): freeing map at 003FB258.
