Time series persistence
Marcos Sánchez Provencio
marcos at BURKE.ATH.CX
Tue Oct 16 04:14:52 EDT 2007
It is all in one slice, with a time dimension. I could replicate the
layer with a shifted view. Maybe it is too much work for the db server
just to get a pretty effect (but I'll try it anyway :-)
Thank you for the idea
PS Is it possible to have an animated gif as a marker?
El lun, 15-10-2007 a las 08:59 -0500, Fawcett, David escribió:
> If you used one layer for each time slice, and you set the filter for that layer dynamically, you might be able to do something like this.
> For example, you could have three layers, 'current', 'older', and 'old'. If you passed in the filter expression for 'current', you would set it to the latest data. You would do the same with the other two layers, setting them to the older data sets.
> You could then symbolize the older and old layers using transparency or color (fading from color to grey?) to make them appear as though they are fading away.
> David.
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Marcos Sánchez Provencio
> Sent: Monday, October 15, 2007 8:25 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] Time series persistence
> Hello there.
> Is it possible to emulate persistence in a time series? I am showing rays hourly, it would be nice to let the older rays fade away slowly (like a radar ping).
> I am using mapbuilder as the client.
> Thank you in advance for the ideas.
