Color coding from two data sources
Mark Leslie
mark.leslie at LISASOFT.COM
Wed Oct 17 00:33:06 EDT 2007
Don Drake wrote:
> On 10/16/07, Mark Leslie <mark.leslie at lisasoft.com> wrote:
>> Don Drake wrote:
>>> Here's my scenario, I have shapefiles containing polygons of
>> zipcodes. I
>>> have a table in Postgres that has a zip code with data that I would like
>> to
>>> thematically map. I am not interested in loading the zipcodes into
>> PostGIS
>>> if I don't have to. I am using PHP/Mapscript, and I was wondering if
>> there
>>> is a way to merge the Postgres data with the shapefile layer on a map?
>>> Thanks.
>>> -Don
>> That depends what you mean by 'merge'. If you want to display both in
>> the same layer, you can come close by defining two layers in the same
>> group (see the GROUP item at
>> http://mapserver.gis.umn.edu/docs/reference/mapfile/layer). If you want
>> to join the two sources together, Jeff has a nice example in the
>> reference docs
>> http://mapserver.gis.umn.edu/docs/reference/mapfile/join#example-2-join-from-shp-file-to-postgresql-table
>> If I've missed the point entirely, then I'll need some more details
>> about what you're trying to end up with.
> Very interesting. It looks like the second link is close to what I need,
> the first is not what I need.
> The thing is that the postgres table the data is coming out of does not have
> a geometry column, the key is the zipcode. Furthermore, it will probably
> come from a query, or a view. I tried using a view with no geometry and
> could not get it to work. The geometry will come from a shapefile.
> If this would work, could I color code using an expression? Is there a
> Mapscript alternative?
> Thanks.
> -Don
If there's no geometry in the table, then the join is your only option
AFAIK. The downside is that joins are only intended for use in queries,
not in styling. I expect that since you're using MapScript, you could
execute a query to determine membership and dynamically setup the
styling, but that's a reasonably horrible solution. You'd be better of
using php to connect directly to postgres (http://au2.php.net/pgsql) to
find a zipcodes and set up your classes from that. Can I ask why you
don't want to load the zipcodes into PostGIS, or extract the table to
shapefile for that matter? Does the zipcode table change frequently?
Mark Leslie
Software Architect
LISAsoft Pty Ltd
www.lisasoft.com
