RV: Don't draw GIF/PNG images on wms clients.
Manuel Ballesteros Cardador
proyectos at ADROCHES.ORG
Wed Oct 17 07:42:38 EDT 2007
Thank Gilles by your response. Now, I have eliminated CONNECTIONTYPE and CONNECTION parameter of the layer to set it to default values and now wms client draw image only when I am moving the image (pan). Do you know the problem?
I have the shapefile in local path, so DATA parameter of layer point to shapefile.
If I try connect to my local wms server from qgis, it work well but don't draw the image, only when pan it.
Best regards!
-----Mensaje original-----
De: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] En nombre de Gilles Bassière
Enviado el: miércoles, 17 de octubre de 2007 12:20
Para: MAPSERVER-USERS at LISTS.UMN.EDU
Asunto: [UMN_MAPSERVER-USERS] [Fwd: Re: [UMN_MAPSERVER-USERS] Don't draw GIF/PNG images on wms clients.]
Hi Manuel
There's something wrong in your layer definition. If I understand your
OnlineResource parameter, you try to expose a WMS stream with URL
http://localhost/cgi-bin/mapserv.exe?, right ?
So you can't feed your layer with the same WMS, it would be client and
server of the same service.
Your connection element should point to your datasource (another WMS, a
shapefile, a postgis DB, etc.).
Regards,
Gilles
Manuel Ballesteros Cardador wrote:
> Hi, Im new in MapServer list.
> I have configured a WMS server and when I try viewing a .map file on
> wms clients (arcmap, qgis), images are not shown in. I can do zoom,
> pan, etc but it is not drawn.
> If I change resourceonline parameter I obtain drawEPP error.
> Do you have any idea?
> Thanks in advance!
> This is the .map file.
> MAP
> NAME "COMARCA"
> STATUS ON
> EXTENT 286421 4210158 400752 4295906
> SIZE 600 500
> SHAPEPATH "./data"
> IMAGECOLOR 125 125 125
> UNITS METERS
> IMAGETYPE PNG
> WEB
> IMAGEPATH "./tmp/ms_tmp/"
> IMAGEURL "./tmp/"
> METADATA
> "wms_title" "WMS Adroches" ##required
> "wms_onlineresource" "http://localhost/cgi-bin/mapserv.exe?"
> "wms_srs" "EPSG:23030"
> END
> END
> PROJECTION
> "init=epsg:23030" ##required
> END
> LAYER
> NAME "Limite"
> STATUS ON
> DEBUG ON
> DATA "comarca"
> TYPE POLYGON
> CONNECTION "http://localhost/cgi-bin/mapserv.exe?map=comarca_wms.map"
> CONNECTIONTYPE WMS
> METADATA
> "wms_title" "Limite Comarca"
> "wms_name" "Limite"
> "wms_server_version" "1.1.1"
> "wms_format" "image/PNG"
> END
> CLASS
> NAME "Comarca"
> STYLE
> COLOR 170 253 172
> OUTLINECOLOR 199 199 199
> END
> END
> END # Layer
> END # Map File
Gilles Bassiere
MAKINA CORPUS
30 rue des Jeuneurs
FR-75011 PARIS
http://www.makina-corpus.com
