Changing layer parameters via CGI with underscore in name
Nathan Vander Wilt
nathan.vanderwilt at ORIONNETWORKSOLUTIONS.COM
Wed Oct 17 12:24:25 EDT 2007
Hello all! I have a layer defined similarly to this:
LAYER
NAME 'dfirm_main'
END
I would like to change some parameters for this on the fly, however I'm wondering if how
to deal with the underscored name in the map_ heirarchy, which depends on underscores as
well. The following example does not work, although if I change the layer name to remove
the underscore in both the .map and the url, then it does work as expected:
http://example/cgi-bin/mapserv?map=/var/www/maps/nvw-test/
test.map&map_dfirm_main_class_color=255+0+0&mode=map
How can I change parameters via CGI on a layer named with an underscore?
thanks,
-natevw
