Solaris AGG Compile...
Nolte, Tim
Tim.Nolte at IPCSWIRELESSINC.COM
Wed Oct 17 16:36:43 EDT 2007
Trent,
Initially it looked this it was going to work. AGG compiled without any
errors and then I tried the MapServer compile only to fail when trying
to compile php_mapscript.so, mapserv compiled without error so I'm a
little confused with that. I'm not sure if there is a bug to address
here. I did have to use 'CC = gcc' instead of 'CC = cc' to get the
compile to work. I'm really hoping that I might be able to figure out
some solutions so that I can get back to using AGG. I'm almost thinking
it would have been better to just go with HostGIS on this server
rebuild. Was there any other things you had to do with your compile of
AGG or MapServer? I'm wondering what compile options others have used
successfully on Solaris?
Is there anyone else out there currently running MapServer 5 on Solaris,
and what version of Solaris?
Timothy J Nolte - tnolte at ilpcs.com
Associate Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS: 616-706-2438
Fax: 616-554-6484
Web: www.ipcswirelessinc.com
-----Original Message-----
Sent: Wednesday, October 17, 2007 2:40 PM
To: Nolte, Tim
Subject: Re: [UMN_MAPSERVER-USERS] Solaris AGG Compile...
Here is a copy of my Makefile.in.SunOS. If this works for you let me
know and I will make a mapserver bug report or a doc somewhere on
mapserver. I could also contact the AGG people and get an alternate
Makefile.in.SunOS. I'm running this on Solaris 9, if this works for you
on Solaris 10 its likely an issue others are struggling with.
---- Makefile.in.SunOS start ----
AGGLIBS= -lagg
AGGCXXFLAGS = -O3 -I/usr/openwin/include -L/usr/openwin/lib
CXX = g++
C = cc
LIB = ar cr
.PHONY : clean
---- Makefile.in.SunOS end ----
good luck
-Trent
Nolte, Tim wrote:
> OK, I'm still struggling here. Here is how I modified my
> Makefile.in.SunOS:
> Changed:
> CXX = CC
> To:
> CXX = gcc
> Changed:
> C = cc
> To:
> C = gcc
> Added:
> AR = ar
> LD = ld
> Changed:
> LIB = CC -xar -o
> To:
> LIB = g++ -xar -o
> I've also made the change of renaming /usr/ccs/bin/ld to
> /usr/ccs/bin/ld-off during the AGG build process. Here is what I'm
> getting as output:
> cd src; make
> make[1]: Entering directory `/usr/local/agg-2.4/src'
> g++ -c -O3 -I/usr/openwin/include -L/usr/openwin/lib -I../include -L./
> agg_arc.cpp -o agg_arc.o
> agg_arrowhead.cpp -o agg_arrowhead.o
> agg_bezier_arc.cpp -o agg_bezier_arc.o
> agg_bspline.cpp -o agg_bspline.o
> agg_curves.cpp -o agg_curves.o
> agg_vcgen_contour.cpp -o agg_vcgen_contour.o
> agg_vcgen_dash.cpp -o agg_vcgen_dash.o
> agg_vcgen_markers_term.cpp -o agg_vcgen_markers_term.o
> agg_vcgen_smooth_poly1.cpp -o agg_vcgen_smooth_poly1.o
> agg_vcgen_stroke.cpp -o agg_vcgen_stroke.o
> agg_vcgen_bspline.cpp -o agg_vcgen_bspline.o
> agg_gsv_text.cpp -o agg_gsv_text.o
> agg_image_filters.cpp -o agg_image_filters.o
> agg_line_aa_basics.cpp -o agg_line_aa_basics.o
> agg_line_profile_aa.cpp -o agg_line_profile_aa.o
> agg_rounded_rect.cpp -o agg_rounded_rect.o
> agg_sqrt_tables.cpp -o agg_sqrt_tables.o
> agg_embedded_raster_fonts.cpp -o agg_embedded_raster_fonts.o
> agg_trans_affine.cpp -o agg_trans_affine.o
> agg_trans_warp_magnifier.cpp -o agg_trans_warp_magnifier.o
> agg_trans_single_path.cpp -o agg_trans_single_path.o
> agg_trans_double_path.cpp -o agg_trans_double_path.o
> agg_vpgen_clip_polygon.cpp -o agg_vpgen_clip_polygon.o
> agg_vpgen_clip_polyline.cpp -o agg_vpgen_clip_polyline.o
> agg_vpgen_segmentator.cpp -o agg_vpgen_segmentator.o
> ctrl/agg_cbox_ctrl.cpp -o ctrl/agg_cbox_ctrl.o
> ctrl/agg_gamma_ctrl.cpp -o ctrl/agg_gamma_ctrl.o
> ctrl/agg_gamma_spline.cpp -o ctrl/agg_gamma_spline.o
> ctrl/agg_rbox_ctrl.cpp -o ctrl/agg_rbox_ctrl.o
> ctrl/agg_slider_ctrl.cpp -o ctrl/agg_slider_ctrl.o
> ctrl/agg_spline_ctrl.cpp -o ctrl/agg_spline_ctrl.o
> ctrl/agg_scale_ctrl.cpp -o ctrl/agg_scale_ctrl.o
> ctrl/agg_polygon_ctrl.cpp -o ctrl/agg_polygon_ctrl.o
> ctrl/agg_bezier_ctrl.cpp -o ctrl/agg_bezier_ctrl.o
> gcc -c -O3 -I/usr/openwin/include -L/usr/openwin/lib -I../include -L./
> ../gpc/gpc.c -o ../gpc/gpc.o
> g++ -xar -o libagg.a agg_arc.o agg_arrowhead.o agg_bezier_arc.o
> agg_bspline.o agg_curves.o agg_vcgen_contour.o agg_vcgen_dash.o
> agg_vcgen_markers_term.o agg_vcgen_smooth_poly1.o agg_vcgen_stroke.o
> agg_vcgen_bspline.o agg_gsv_text.o agg_image_filters.o
> agg_line_aa_basics.o agg_line_profile_aa.o agg_rounded_rect.o
> agg_sqrt_tables.o agg_embedded_raster_fonts.o agg_trans_affine.o
> agg_trans_warp_magnifier.o agg_trans_single_path.o
> agg_trans_double_path.o agg_vpgen_clip_polygon.o
> agg_vpgen_clip_polyline.o agg_vpgen_segmentator.o ctrl/agg_cbox_ctrl.o
> ctrl/agg_gamma_ctrl.o ctrl/agg_gamma_spline.o ctrl/agg_rbox_ctrl.o
> ctrl/agg_slider_ctrl.o ctrl/agg_spline_ctrl.o ctrl/agg_scale_ctrl.o
> ctrl/agg_polygon_ctrl.o ctrl/agg_bezier_ctrl.o ../gpc/gpc.o
> g++: language ar not recognized
> /usr/local/lib/gcc/i386-pc-solaris2.10/3.4.6/crt1.o: In function
> `_start':
> crt1.s:(.text+0x5c): undefined reference to `main'
> collect2: ld returned 1 exit status
> make[1]: *** [all] Error 1
> make[1]: Leaving directory `/usr/local/agg-2.4/src'
> make: *** [src/libagg.a] Error 2
> Any thoughts, anyone? Thanks.
> - Tim
> iPCS Wireless, Inc.
> Kentwood, MI 49512
> PCS: 616-706-2438
> Fax: 616-554-6484
> From: Trent Erickson [mailto:trente at umn.edu]
> Sent: Tuesday, October 16, 2007 9:45 PM
> To: Nolte, Tim
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> The sunfreeware gcc package is compiled with --with-ld=/usr/ccs/bin/ld
> so it can be hard to get around it. (you can see this by running g++
-v)
> The sun ld version did not want to compile agg for me. I ended up
> renaming /usr/ccs/bin/ld to /usr/ccs/bin/ld-off I then put it back
> after the compile. This of course requires root access.
> It is not very elegant but it worked. If anyone has any other
> suggestions I'd love to know how to force the proper ld with resorting
> to this. It just plain ignored the makefile and environment settings.
> -Trent
> Nolte, Tim wrote:
>> OK, well here's my setup. I have the following sunfreeware packages
>> installed:
>> gcc-3.4.6-sol10-x86-local
>> make-3.81-sol10-x86-local
>> automake-1.10-sol10-x86-local
>> libtool-1.5.24-sol10-x86-local
>> I've set my PATH environment to use '/usr/local/bin' before
>> '/usr/ccs/bin'. And my g++/gcc/make/ar/ld are all GNU when I run
> 'type'
>> on them. I did notice that gcc reports (Configured with: ../configure
>> --with-as=/usr/ccs/bin/as --with-ld=/usr/ccs/bin/ld --enable-shared
>> --enable-languages=c,c++,f77) so I'm not sure if this would be an
> issue.
>> Thanks for any other thoughts.
>> iPCS Wireless, Inc.
>> Kentwood, MI 49512
>> PCS: 616-706-2438
>> Fax: 616-554-6484
