Problems with Mapserver 5
José Ramón López
joseramonlopez at GMAIL.COM
Thu Oct 18 05:19:27 EDT 2007
Thxs Thomas.
The problems was related with the TRANSPARENCY parameter, i chaned it and
works fine.
Thx u very much
2007/10/17, thomas bonfort <thomas.bonfort at gmail.com>:
> José,
> TRANSPARENCY 0 has been deprecated in 5.0 and been replaced with
> OPACITY. and a layer with 0 opacity being fully transparent, it is not
> drawn.
> tb
> On 10/17/07, José Ramón López <joseramonlopez at gmail.com> wrote:
> > Hi list.
> > Im trying to configure mapserver with Oracle Spatial or OCI connection
> > This is my layer:
> > LAYER
> > NAME CARRETERAS
> > TYPE LINE
> > STATUS ON
> > CONNECTIONTYPE OGR
> > CONNECTION " OCI:sde/password at SDE"
> > DATA "SDE.RED_CARRETERAS"
> > DUMP TRUE
> > DEBUG ON
> > PROCESSING "CLOSE_CONNECTION=DEFER"
> > TRANSPARENCY 0
> > PROJECTION
> > "init=epsg:23030"
> > END
> > CLASS
> > STYLE
> > COLOR 0 0 0
> > END
> > NAME 'Carreteras'
> > END
> > METADATA
> > "wms_title" "Red Carreteras"
> > "wms_keywordlist" "WMS Carreteras"
> > "wms_srs" "epsg:23030"
> > "wms_extent" "164590 4062740 579080 4266350"
> > END
> > END
> > Mapserver allways send to me a blank image.
> > I'd use shp2img , and allways send me a blank image, with this command:
> > C:\ms4w-v5\tools\mapserv>shp2img.exe -m c:\ms4w-v5\maps\map\wms.map -i
> png
> > -o C:\test.png -all_debug 9 -l CARRETERAS
> > msDrawMap(): Layer 1 (CARRETERAS), 0.000s
> > msDrawMap(): Drawing Label Cache, 0.000s
> > msDrawMap() total time: 0.000s
> > msFreeMap(): freeing map at 0144B390.
> > and made some test for testing oracle connection with og2info, and works
> > correctly, like:
> > C:\ms4w-v5\tools\mapserv>ogrinfo.exe OCI:sde/password at SDE:
> sde.RED_CARRETERAS
> > -SO
> > INFO: Open of `OCI:sde/sde at SDE:sde.RED_CARRETERAS'
> > using driver `OCI' successful.
> > 1: sde.RED_CARRETERAS
> > if i use the command with -al option, it sends to me all information
> > allocated in this layer.
> > Is the problem related with system enviroment?
> > In httd.conf:
> > SetEnv PATH "C:/Oracle/oracle10g/BIN"
> > SetEnv TNS_ADMIN "C:/Oracle/oracle10g/NETWORK/ADMIN"
> > SetEnv ORACLE_SID SDE
> > SetEnv ORACLE_BASE "C:/Oracle/oracle10g"
> > SetEnv ORACLE_HOME "C:/Oracle/oracle10g"
> > SetEnv LD_LIBRARY_PATH "C:\Oracle\oracle10g\LIB"
> > and de tnsadmin.ora file
> > SDE=
> > (DESCRIPTION =
> > (ADDRESS_LIST =
> > (ADDRESS = (PROTOCOL = TCP)(HOST = 172.19.133.19)(PORT = 1521))
> > (CONNECT_DATA =
> > (SERVICE_NAME = sde)
> > Windows 2003 System Enviroment:
> Path=\ms4w\Apache\cgi-bin;\ms4w\tools\gdal-ogr;\ms4w\tools\mapserv;\ms4w\tools\shapelib;\ms4w\proj\bin;\ms4w\tools\shp2tile;\ms4w\tools\shpdiff;\ms4w\tools\avce00;C:\oracle\Oracle10g\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
> > PROJ_LIB=\ms4w-v5\proj\nad
> > ORACLE_HOME=C:\oracle\Oracle10g
> > In ms_erro.txt file nothing is registered.
> > Thxs
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071018/73bff467/attachment.html
