First exercise using Java Mapscript
Peter Lee (Planning Data Factory)
peter.lee at PLANNINGDATAFACTORY.COM.AU
Fri Oct 19 02:13:14 EDT 2007
Dear List,
I have some experience using Mapserver CGI but am a newie to Java Manpscript. I tried to compile my first program in windows XP with the error:
import edu.umn.gis.mapscript.*;
public class mapscript_basic {
public static void main(String[] args) {
System.loadLibrary("mapscript");
mapObj mapobject;
imageObj mapimage;
String mapfile;
// set the map file to use
mapfile = "global.map";
// create a mapObj, initilized with the mapfile above
mapobject = new mapObj(mapfile);
// create an imgObj that has an image of the map
mapimage = mapobject.draw();
// save the mapimage to a file
mapimage.save("worldmap.png",mapobject);
Error:
mapscript_basic.java:1: package edu.umn.gis.mapscript does not exist
In fact, I have placed the two library files mapscript.jar and mapscript.dll in the folder JAVA_HOME\lib and set the env variable CLASSPATH to JAVA_HOME\lib.
I got the files from the ms4w download ver 2.2.6. The library files are located at the folder C:\ms4w\Apache\cgi-bin\mapscript\java.
Any help to solving the problem will be greatly appreciated.
Peter
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071019/93af5fe4/attachment.html
