Problem with shp2img
Matthew Perry
perrygeo at GMAIL.COM
Mon Oct 22 12:20:24 EDT 2007
Marc,
Depending on what type of system you're on you can either set your
$LD_LIBRARY_PATH env variable or add the proper directories to
/etc/ld.so.conf and run ldconfig.
Either way, the goal is to tell mapserver where to find the libraries
at runtime.
- matt
On 10/22/07, Marc Compte <mcompte at sigte.udg.es> wrote:
> Hi,
> We are trying the shp2img tool but the following error shows up:
> ./shp2img: error while loading shared libraries: libgdal.so.1: cannot
> open shared object file: No such file or directory
> We do have that library but we are guessing it might not be at the
> proper place for UMN MapServer to find it. We currently have it at:
> /usr/local/OpenSource_FDO/Thirdparty/GDAL1.3/linux/lib/optimized/libgdal.so.1
> /usr/local/OpenSource_FDO/Thirdparty/GDAL1.3/linux/lib/optimized/libgdal.so.1.9.0
> /usr/local/OpenSource_FDO/Thirdparty/GDAL1.3/src/.libs/libgdal.so.1
> /usr/local/OpenSource_FDO/Thirdparty/GDAL1.3/src/.libs/libgdal.so.1.9.0
> Any help will be greatly appreciated, thanks :)
> Marc
Matthew T. Perry
http://www.perrygeo.net
"Never ascribe to malice, that which can be adequately explained by
incompetence."
