WG: [UMN_MAPSERVER-USERS] Displaying elevation data
Arnd Wippermann
arndw at WTAL.DE
Mon Oct 22 15:02:34 EDT 2007
The tools from Matthew are quite good.
To colorize a map it's also possible with Mapserver. Use colorrange or query
[pixel]
CLASS
STYLE
RANGEITEM "EW_QKM2004"
DATARANGE 140 15987
COLORRANGE 255 255 178 189 0 38
OUTLINECOLOR 0 0 0
END
END
[Quelle:http://www.geog.fu-berlin.de/de/Karto/umn_karten/choro.shtml#colorra
nge]
CLASSITEM "[pixel]"
CLASS
EXPRESSION ([pixel] >= 0 AND [pixel] < 8)
COLOR 0 255 255
END
Mit freundlichen Grüssen
Arnd Wippermann
http://gis.ibbeck.de/ginfo/
-----Ursprüngliche Nachricht-----
Von: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] Im
Auftrag von Matthew Perry
Gesendet: Montag, 22. Oktober 2007 07:13
An: MAPSERVER-USERS at LISTS.UMN.EDU
Betreff: Re: [UMN_MAPSERVER-USERS] Displaying elevation data
Vishal,
In terms of visualizing elevation data, there are a number of good options:
- create a hillshade and overlay that on the elevation layer at 50% opacity
- colorize the elevation layer (ie green to white instead of black&white)
- generate a vector contour layer
Mapserver itself is not capable of doing this processing; you can achieve
these through many other pieces of software such as GRASS, MicroDEM, GDAL,
etc. I wrote a few custom apps for this purpose that are described on my
site : http://www.perrygeo.net/wordpress/?p=7
Mapserver only does 2D so true 3D is not possible.
- matt
On 10/21/07, Vishal Nagpal <vishu_73ns at yahoo.com> wrote:
> I am trying to display elevation data dt1 and dt2 files.
> I am getting a gray scale image as output. Though it gives an
> impression of varying heights but Is it possible to do more with it,
> like see contours, or see 3D.
> I have tried changing scale but it only varies the shades of grey.
> Surprisingly A combine layer of tif and elevation shows some color
> shades. I don't know why?
> Vishal
Matthew T. Perry
"Never ascribe to malice, that which can be adequately explained by
incompetence."
