MapServer and PostGIS GEOMETRY type]
Jan Hartmann
j.l.h.hartmann at UVA.NL
Wed Oct 31 07:01:01 EDT 2007
If you own mapinfo, there is an easy way to use mapbasic to create a
script that will split your table up based upon the entity type. It's a
matter of looping through a select statement that filters on object type
and then save the selection as tablename_entity_type.TAB.
Jan Hartmann schreef:
> I really would advise you to split them up. Being lazy always creates
> more work in the end, I can tell you. I have lots of personal
> experience in that field :-)
> Jan
> Delfos, Jacob wrote:
>> Hi Jukka,
>> When I have the data a bit cleaned up, I'll have a look if I can put
>> something together. Currently I'm still in the process of "sifting
>> through" :)
>> I'm dealing with a lot of MapInfo files with mixed geometries, and I
>> want to see if I can get away with being lazy (meaning I don't split up
>> tables by geometry).
>> Regards,
>> Jacob
>>> -----Original Message-----
>>> From: Rahkonen Jukka [mailto:Jukka.Rahkonen at mmmtike.fi] Sent: 30
>>> October 2007 14:52
>>> To: Delfos, Jacob; MAPSERVER-USERS at LISTS.UMN.EDU
>>> Subject: RE: [UMN_MAPSERVER-USERS] MapServer and PostGIS GEOMETRY type
>>> Hi Jacob,
>>> Would it be impossible for you to create a couple of such records
>>> and make a controlled trial to see what really happens?
>>> -Jukka Rahkonen-
>>> From: UMN MapServer Users List on behalf of Delfos, Jacob
>>> Sent: Tue 30.10.2007 0:53
>>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>>> Subject: Re: [UMN_MAPSERVER-USERS] MapServer and PostGIS GEOMETRY type
>>> Hi Jan,
>>> Thanks for your reply. But I still need to find out how MapServer will
>>> deal with the records that contain an unexpected geometry type. I could
>>> have a polygon layer pointing to a table which I expect to contain
>>> polygons. But if the geometry type of the table is GEOMETRY, then it
>>> could contain a line object. What will MapServer do?
>>> If I do an attribute query on such a table, will it return matching
>>> records even if the geometry object is a line, though the layer is a
>>> polygon layer?
>>> Regards,
>>> Jacob
>>>> From: Jan Hartmann [mailto:j.l.h.hartmann at uva.nl] Sent: 29 October
>>>> 2007 20:13
>>>> To: Delfos, Jacob
>>>> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
>>> GEOMETRY type
>>>> Hi Jacob,
>>>> The Mapfile Reference Manual, chapter Layer says
>>>> (http://mapserver.gis.umn.edu/docs/reference/mapfile/layer)
>>>> TYPE [point|line|polygon|circle|annotation|raster|query|chart]
>>>> Specifies how the data should be drawn. Need not be the same
>>>> as the shapefile type. For example, a polygon shapefile may be
>>>> drawn as a point layer, but a point shapefile may not be drawn as a
>>>> polygon layer.Common sense rules.
>>>> You probably just have to try it out on your data.
>>>> Jan
>>>>> Hi List,
>>>>> For a particular client I have to translate a lot of
>>>> MapInfo files into
>>>>> PostGIS. Some files may contain some different geometries,
>>>> which ogr2ogr
>>>>> doesn't like. So I force the geometry type to "GEOMETRY" (-nlt
>>>>> GEOMETRY). It translates fine, and seems to draw fine in
>>>> MapServer. But
>>>>> how does MapServer really deal with it?
>>>>> If I have a polygon layer, and point it to a PostGIS table
>>>> that contains
>>>>> objects of the type "GEOMETRY", does it simply ignore
>>>> anything that is
>>>>> not a polygon? What about the results of attribute queries?
>>>> Would those
>>>>> be filtered on the geometry type of the layer?
>>>>> I can avoid using "GEOMETRY type" by translating the files
>>>> in FME, but
>>>>> I'd prefer to recommend an Open Source solution.
>>>>> Regards,
>>>>> Jacob
>>>>> *JACOB DELFOS
>>>>> GIS ANALYST
>>>>> *Maunsell Australia Pty Ltd
>>>>> 629 Newcastle Street, Leederville, WA 6007
>>>>> PO Box 81, Leederville, WA 6902
>>>>> Western Australia
>>>>> ABN 20 093 846 925
>>>>> Tel + 61 8 9281 6185
>>>>> Fax + 61 8 9281 6297
>>>>> _jacob.delfos at maunsell.com_
>>>>> This email and any attachments are intended solely for the named
>>>>> recipient and are confidential. The copying or distribution
>>>> of them or
>>>>> any information they contain by anyone other than the named
>>>> recipient is
>>>>> prohibited. If you have received this document in error,
>>>> please notify
>>>>> the sender and delete all copies from your computer system
>>>> and destroy
>>>>> all hard copies. It is the recipient's responsibility to
>>> check this
>>>>> email and any attachments to this email for viruses before use.
>>> recipient and are confidential. The copying or distribution of them
>>> or any information they contain by anyone other than the named
>>> recipient is prohibited. If you have received this document in
>>> error, please notify the sender and delete all copies from your
>>> computer system and destroy all hard copies. It is the recipient's
>>> responsibility to check this email and any attachments to this email
>> recipient is prohibited. If you have received this document in error,
>> please notify the sender and delete all copies from your computer
Milo van der Linden
skype: milovanderlinden <skype:milovanderlinden?add>
mlinden at zeelandnet.nl <mailto:mlinden at zeelandnet.nl>
milovanderlinden at gmail.com <mailto:milovanderlinden at gmail.com>
milo at 3dsite.nl <mailto:milo at 3dsite.nl>
http://www.3dsite.nl
De informatie in dit bericht reflecteert mijn persoonlijke mening en
niet die van een bedrijf of instantie. Aan de informatie kunnen geen
rechten worden ontleend. Indien dit bericht onderdeel is van een forum,
mailing-list of community dan gelden automatisch de bij het betreffende
medium behorende voorwaarden. The information in this message reflects
my personal opinion and not that of a company or public body. All rights
reserved.If this message is contained in a mailing-list or community,
the rights on the medium are automatically adapted.
