Getting Blank Image : New User
Gregor Mosheh
gregor at HOSTGIS.COM
Mon Sep 3 10:22:18 EDT 2007
cool frenz wrote:
> I am a new user of mapserver. I am trying to view the available shape
> file using php mapscript. I have created a simple map file for the
> same.But on running it through browser i am getting a completely blank
> image as output. Please help.
Nine times out of ten, a blank image means that your projections don't
line up. I notice in your sample that you don't specify a projection for
the output map, nor for the layer; though you do specify a extent in meters.
I'd recommend adding a PROJECTION block to both the top level (the MAP
block) and to the LAYER, for starters.
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
only if you can restore." - AMANDA
