Can't execute mapserv.exe from Apache 2 cgi-bin folder
Francesco Sozzi
fsozzi at INTERCAD.CH
Thu Sep 6 08:46:23 EDT 2007
ah... ok, it works!
Now I tried with FireFox with ".exe" and it works. There is something wrong in my IE; if I put ".exe" with my IE, it tries to download a file instead of executing...
Thank for help!
Best regards
Francesco
----- Original Message -----
To: MAPSERVER-USERS at LISTS.UMN.EDU
Sent: Thursday, September 06, 2007 2:30 PM
Subject: Re: [UMN_MAPSERVER-USERS] Can't execute mapserv.exe from Apache 2 cgi-bin folder
you need to include the extension of the mapserver cgi file... you need to put the ".exe" at the end of your url and it will work (I already try it ;) ):
http://213.133.227.245/cgi-bin/mapserv.exe
Rodrigo.
On 9/6/07, Francesco Sozzi <fsozzi at intercad.ch > wrote:
Hi Rodrigo,
Thanks for help.
Unfortunatelly I already have the following line:
ScriptAlias /cgi-bin/ "C:/Programmi/Apache Group/Apache2/cgi-bin/"
And if I try to run http://213.133.227.245/cgi-bin/mapserv I have a 404 error (file not found).
So, I think there is something else wrong...
I attacched my configuration file.
Best regards
Francesco
Sent: Thursday, September 06, 2007 1:24 PM
Hi Francesco
You also need to have a Script Alias in your httpd.conf file like this:
ScriptAlias /cgi-bin/ "/ms4w/Apache/cgi-bin/"
and then (after restarting apache) you can try to access mapserver like:
http://yourservername:port/cgi-bin/mapserv.exe
Rodrigo.
On 9/6/07, Francesco Sozzi <fsozzi at intercad.ch> wrote:
Hi All,
I'm trying to let Mapserver provide as WMS server, but I have an Apache configuration problem.
I've put mapserv.exe into C:/Programmi/Apache Group/Apache2/cgi-bin.
But I can't execute from browser (it is as it does not see/execute the file).
I have no problem in Apache 1.x but I have problem with a standard installation of Apache 2 on Windows XP.
In my httpd.conf I have this cgi-bin folder definition:
<Directory "C:/Programmi/Apache Group/Apache2/cgi-bin">
AllowOverride None
Options None
Order allow,deny
Allow from all
</Directory>
How can I set execution permission?...
Best regards
Francesco
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070906/31fd34a7/attachment.html
