I installed MapServer and the Apache Web Server
Rahkonen Jukka
Jukka.Rahkonen at MMMTIKE.FI
Fri Sep 7 12:24:28 EDT 2007
When it comes to your first problem, starting Apache, if you first open a Windows command window and start httpd.exe from there you will have more time to read the error messages which perhaps appear on the screen.
-Jukka Rahkonen-
-----Original Message-----
From: UMN MapServer Users List on behalf of Solomon, Scott
Sent: Fri 7.9.2007 18:57
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] I installed MapServer and the Apache Web Server
I installed MapServer and the Apache Web Server. The attached pics show
that. When I manually start Apache each time, by clicking on
/ms4w/Apache/bin/httpd.exe the empty DOS window opens, but just for a
split second and disappears. It appears just along enough that I could
grab a screen capture of it:
But it either closes automatically, or runs in the background, so how
would I be able to close it?
Most importantly, I went to request a map image directly from MapServer
through both Internet Explorer and Mozilla Firefox. Should I see a
MapServer toolbar with a button that says "Request Map" or something
along those lines in the browser window? Right now I don't, which leads
me to believe I installed MapServer unsuccessfully.
What should I be looking for?
Scott Solomon
Data Mining Analyst
Arlington Center
3434 Washington Blvd, 2nd Floor
Arlington, VA 22201
voice 703-284-3233
fax 703 284 1375
Type: image/jpeg
Desc: image001.jpg
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070907/ea1f9e76/image001.jpg
Type: image/gif
Desc: image002.gif
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070907/ea1f9e76/image002.gif
