difference between shp2img and Mapserver
Bart van den Eijnden
bartvde at GMAIL.COM
Mon Sep 10 10:46:21 EDT 2007
Hi Frank,
this will also present in 4.8.4 and 4.10.2.
I've opened the following bug:
http://trac.osgeo.org/mapserver/ticket/2301#preview
and set the target to FUTURE. Feel free to update to 5.0.1 or 5.2 if
appropriate.
Best regards,
Bart
On 9/10/07, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Bart van den Eijnden wrote:
> > Hi list,
> > if I omit a NAME from a LAYER, shp2img will still draw the layer, but
> > Mapserver will not draw it using &mode=map&layers=all.
> > Would it not be better to generate an error/warning message saying the
> > NAME is required in all cases?
> > It took me quite a while to figure out what I was doing wrong ... :-)
> Bart,
> Is this behavior new in 5.0? If not, then I would encourage you to file a
> ticket on the issue, and hopefully something can be done for 5.0.1 or 5.2.
> If this behavior is new in 5.0 then we need to know immediately so we can
> consider fixing it before the next RC.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070910/45569ba6/attachment.html
