Problem with long DATA object in an Oracle LAYER
Damien Corpataux
damien.corpataux at CAMPTOCAMP.COM
Tue Sep 11 04:34:30 EDT 2007
Andreas Albarello wrote:
> Damien Corpataux wrote:
>> Hello List,
>> I ran into memory corrption with a long sql query in the DATA object,
>> for an Oracle LAYER. It is obviously due to Mapserver memory
>> allocation mechanism. The corruption occurs when the DATA is longer
>> than ca. 2037 characters.
>> Do you know if Mapserver has a way of modifying the possible
>> allocated memory limit? In header files? By applying a patch?
>> Any idea is welcome!
> Damien,
> replace all occurrences of table_name[2000] with table_name[n] (where
> n is the maximum data statement length you would like to have) in
> maporaclespatial.c. That should fix it.
> Best regards,
Hello Andreas,
Thanks for the Tip! It works! I suppose that the default limit (2000) is
a good compromise for memory_usage/use_cases_coverage, so let's patch
the source when a project needs it (and perhaps buy some more RAM for
the server :-))
Thanks a lot for the precious help, regards,
Damien
Camptocamp SA
Damien Corpataux
PSE A
CH-1015 Lausanne
+41 21 619 10 22 (Direct)
+41 21 619 10 10 (Centrale)
+41 21 619 10 00 (Fax)
P Please consider the environment
Do you really need to print this email?
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070911/cf7e54c7/attachment.html
