Mapserver SDE 9.2 Question
Howard Butler
hobu.inc at GMAIL.COM
Tue Sep 11 11:43:04 EDT 2007
No, the 9.1 ArcSDE SDK dlls are not sufficient to connect to 9.2 with
the 9.2 plugin. The plugins are linked against each specific
version of the ArcSDE SDK and have to be matched. The use of plugins
makes this less obnoxious than it was in the past, which required
swapping out the entire libmap.dll, but it is still some hassle.
The rules for ArcSDE MapServer connections are as follows:
- If you have to connect to both ArcSDE X.1 and X.2 servers, use the
X.2 version of the ArcSDE SDK. You can usually connect to a X.1
version server with X.2 version client DLLs without ill effect.
- To connect to X.2 servers, you *have* to use X.2 versions of the
ArcSDE SDK.
- Do not use both the X.1 and X.2 versions of the plugins in the same
MapServer map if you have to connect to both X.1 and X.2 version
servers. Just use X.2.
Howard
On Sep 11, 2007, at 10:21 AM, Josh Hevenor wrote:
> I had a quick question on using the msplugin_sde_92.dll to connect
> to an SDE service from mapserver. The SDE Notes from the README
> file state the following:
> As of Map Server 5.0 (including betas and release
> candidates), the following applies:
> Steps to Enable SDE 9.1 and 9.2 Support in MS4W's Map Server
> 1. Make sure the ArcSDE? SDK dlls for 9.1 are available on… But
> it doesn’t mention arcSDE 9.2 SDK dll’s for connecting to a 9.2
> service. Are the 9.1 dll’s sufficient? I’m just working through my
> setup and thought I should clear this up as I go along. Thanks,
> Josh Hevenor
> Application Developer
> ____________________________________________
> 5230 South Service Road
> Burlington, Ontario
> L7L 5K2 Canada
> Phone: 905-333-4544 ext. 19
> Fax: 905-333-0455
> Cell: 905-320-7525
> Email: josh.hevenor at dpra.com
> Internet: http://www.dpra.com
> <image001.jpg>
> Attention:
> Privileged/Confidential Information may be contained in this
> message. Disclosure to any person other than the named recipient is
> unauthorized. If you are not the intended recipient, please delete
> all copies of this information and kindly notify the sender by
> reply email. Opinions, conclusions and other information in this
> message that do not relate to the official business of DPRA shall
> be understood as neither given nor endorsed by it. DPRA and any of
> its subsidiaries reserve the right to monitor all e-mail
> communications through its networks. Thank you.
