FWTools 1.3.6 using mapserver 5.0.0-beta4
Milo van der Linden
mlinden at ZEELANDNET.NL
Wed Sep 12 12:35:21 EDT 2007
Frank,
Thank you for the response, I understand your concern and will keep it in
mind. For now this is at least a working situation under IIS, which on
itself is tricky enough allready. The enduser however is stricly a
microsoft minded firm and Apache was no option so WAMP or ms4w was no
option.
Basically the situation that I now have is a FWtools that is a stripped
ms4w installation without apache and mysql, but with the proj and gdal
definitions from FWTools.
> Milo van der Linden wrote:
>> What I did:
>> - Installed fwtools
>> - copied only the php_mapscript.dll from the ms4w package into
>> c:\PHP\ext
>> - added extension=phpmapscript.dll to my php.ini
>> - made sure the paths point to C:\PHP and C:\FWTools\bin and so on.
>> Is there anyone that can tell me why libmap.dll is teasing me?
> Milo,
> I do not believe you should mix the php_mapscript.dll from MS4W with
> the mapserver build done for FWTools. FWTools is a "moving target"
> compiled against the latest and greatest mapserver source at the time
> it is released. So there is no way to ensure that the php mapscript
> corresponds with the correct structures, functions and so forth from
> the FWTools mapserver dlls.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
Milo van der Linden
<a href="http://somafm.com/"><img
src="http://somafm.com/linktous/450x25sfm1.gif" alt="SomaFM" border=0
width=450 height=25 ></a>
