antialias lines
Bailey
Bailey at TEXASSABAL.COM
Thu Sep 13 12:14:43 EDT 2007
I made your change from "Width 2" to "Size 2", but I still have the same
problem. Upon another user's recommendation I made the contour lines thin,
which improved their look tremendously, but still wonder how to antialias
thicker lines. Do you know if there is a test MAPFILE & .shp file with wavy
lines, with which I could test my system?
Thanks,
Bailey
-----Original Message-----
From: Steve Lime [mailto:Steve.Lime at dnr.state.mn.us]
Sent: Wednesday, September 12, 2007 3:40 PM
To: Bailey Landress
Subject: Re: [UMN_MAPSERVER-USERS] antialias lines
Try SIZE 2 instead of WIDTH 2. I don't think the cartoline code respects
width.
Steve
>>> On 9/12/2007 at 5:04 AM, in message
<LISTSERV%200709120504083918.0164 at LISTS.UMN.EDU>, Bailey Landress
<bailey at TEXASSABAL.COM> wrote:
> Trying to fix jagged lines. See anything wrong with the Mapfile below?
> When I change IMAGEMODE to RGBA the background of my map turns black.
Also
> if I take out SYMBOL "cartoline" from the Style tag under Layer, I do
not
> see any change in regard to antialiasing. Any help would be greatly
> appreciated. Thanks.
> MapServer version 4.10.2
> In MAP:
> IMAGETYPE png24
> OUTPUTFORMAT
> NAME png24
> DRIVER "GD/PNG"
> MIMETYPE "image/png"
> IMAGEMODE RGB
> EXTENSION "png"
> END
> SYMBOL
> NAME 'cartoline'
> TYPE cartoline
> LINECAP round
> LINEJOIN round
> LINEJOINMAXSIZE 3
> END
> LAYER
> NAME "Contours"
> STATUS on
> TYPE LINE
> DATA "Contours"
> SYMBOLSCALE 24000
> TRANSPARENCY alpha
> CLASS
> STYLE
> COLOR 000 000 000
> SYMBOL "cartoline"
> ANTIALIAS TRUE
> WIDTH 2
> END
> END
> END
> Bailey
