Which Projection to use?
Fawcett, David
David.Fawcett at STATE.MN.US
Mon Sep 17 10:06:37 EDT 2007
If all of your data is in the same projection, you don't need to define
projections in your map file.
One exception is that if you are serving the data up as a WMS or WFS,
you will need to define MAP and LAYER level projections. You will
likely also need to add metadata at the LAYER and MAP? level that
includes information about the projection.
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of LITTLE Nelson
Sent: Monday, September 17, 2007 1:42 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Which Projection to use?
Hi all,
I have shape files which are in x,y coordinate form (units of meters)
and didn't think I needed any projection information because I was
dealing with such a small area, thus never defined any PROJECTION info
in my map file. Now I am getting the following error:
[MapServer Error]: _msProcessAutoProjection(): WMS/WFS AUTO PROJECTION
must be in the format 'AUTO:proj_id,units_id,lon0,lat0' (got '').
I gather from the error message that I need to define at least a map
level projection entry, but I am not sure what I should use?
Any help much appreciated
Cheers,
Nelson
Disclaimer :
The contents of this e-mail including any attachments are intended only
for the person or entity to which this e-mail is addressed. If you are
not, or believe you may not be, the intended recipient, please advise
the sender immediately by return e-mail, delete this e-mail and destroy
any copies. Tenix does not warrant nor guarantee that this email
communication is free from errors, virus, interception or interference.
