5.0+AGG performance
Andreas Albarello
andreas.albarello at TERRITORIUMONLINE.COM
Tue Sep 18 06:54:47 EDT 2007
Guillaume Sueur wrote:
> I've just done some tests with AGG rendering, and I'm a little bit
> desappointed, but it may be because of my unexperience with agg.
> 1. files are big -> from 21 to 80 ko where the raw PNG was 6.9 ko
Guillaume,
unfortunately, the better the image is going to look, the bigger it will
be, that's pretty obvious. AGG looks so great because of the superb
antialiasing. The drawback of antialiasing is that it affects filesize
due to the additional colors and shadings it uses. You could try to play
with the quantization settings as explained here:
http://mapserver.gis.umn.edu/docs/howto/agg-rendering-specifics
By reducing the number of colors in the image, you should be able to get
smaller files.
> 2. There are artefacts on the map (some pixels are drawn in some
> irrelevant places)
I personally didn't notice anything like that in my maps, but if yours
do indeed show noticeable artifacts I'd suggest filing a bug report with
a testcase. This should help the devs reproducing and fixing the issue.
Best regards,
Andreas Albarello
Analysis & SW Development
Territorium Online srl/GmbH
Via Buozzi Str. 12
I 39100 Bolzano/Bozen
Phone: +39 0471 068611
Fax: +39 0471 068619
email: andreas.albarello at territoriumonline.com
web: http://www.territoriumonline.com
