MapServer 5.0.0 released!
Nolte, Tim
Tim.Nolte at IPCSWIRELESSINC.COM
Fri Sep 21 09:48:34 EDT 2007
Ok, here is my symbol and layer definitions.
SYMBOL
NAME 'aliased'
TYPE SIMPLE
ANTIALIAS FALSE
END
LAYER
GROUP "Propagations"
NAME "-98dBm to -104dBm (Outdoor Rural)"
STATUS ON
TILEINDEX "propagations/104/tileindex"
TILEITEM "location"
TYPE POLYGON
# Class: -98dBm to -104dBm (Outdoor Rural)
CLASS
MINSCALE 0
MAXSCALE 1200000
STYLE
SYMBOL "aliased"
COLOR 255 128 0
OUTLINECOLOR 255 128 0
END
END
END
Does anyone see something that isn't right? My default application
interface is Chameleon, however just using the basic cgi index.html &
viewer-template.html ways of rendering are outputting the same thing (no
legend images for layers using SYMBOL "aliased"). Prior to this patch
those legend images showed up fine. I'm pretty sure it has something to
do with adding a symbol to the class.
Timothy J Nolte - tnolte at ilpcs.com
Associate Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS: 616-706-2438
Fax: 616-554-6484
Web: www.ipcswirelessinc.com
-----Original Message-----
From: thomas bonfort [mailto:thomas.bonfort at gmail.com]
Sent: Thursday, September 20, 2007 10:28 AM
To: Nolte, Tim
Subject: Re: [UMN_MAPSERVER-USERS] MapServer 5.0.0 released!
I can't reproduce this here... the legend icon shows up correctly (i.e.
aliased)
how are you drawing the legend icons?
tb
On 9/20/07, Nolte, Tim <Tim.Nolte at ipcswirelessinc.com> wrote:
> I guess I'm not totally out of the dark yet. I didn't notice it but
when
> using the patch the legend images for the layers I've added the SYMBOL
> 'aliased' to don't show up now. Any tip? I'm assuming that this patch
is
> looking specifically for the "SYMBOL 'aliased'" so I can't simply add
> more symbols that have the correct color. I think this might be the
> problem because it's trying to use that symbol to make the legend
image.
> iPCS Wireless, Inc.
> Kentwood, MI 49512
> PCS: 616-706-2438
> Fax: 616-554-6484
> > Sent: Tuesday, September 18, 2007 1:46 PM
> > To: Nolte, Tim
> > Cc: MAPSERVER-USERS at lists.umn.edu
> > On 9/18/07, Nolte, Tim <Tim.Nolte at ipcswirelessinc.com> wrote:
> > > Thomas,
> > > I'll give this a try, and see what I get. Thanks. I'll let you how
> it
> > > works. Just so I get this straight I add "ANTIALIAS FALSE" to my
> > layer
> > > after the patch and that layer won't be antialiased, correct?
> > nope, that's not it..
> > you create the symbol definition in your symbol file or inlined in
> > your mapfile. and then you set the layers you want rendered fast to
> > LAYER
> > NAME blablba
> > DATA ...
> > CLASS
> > STYLE
> > COLOR r g b
> > SYMBOL 'aliased'
> > END
> > END
> > END
> > it's slower than gd but did speed up dense line drawings by a factor
> > of 3 when i tried it, less with polygons.
> > tb
