Error while running OpenEV on FWTools 1.3.7
Frank Warmerdam
warmerdam at POBOX.COM
Fri Sep 21 13:01:46 EDT 2007
Piero,
This question is best addressed to the FWTools mailing list since it is
FWTools specific. My guess is that you have an older copy of libeay32.dll
in your C:\windows\system32 directory and this is overriding the one
provided by FWTools. You could try copying the FWTools libeay32.dll over
the one in \windows\system32 but you run a non-trivial risk of breaking
some other application that depends on the old version in some funky way.
So if you do that,I'd encourage you to first rename the old one, so you
can get it back if you need to.
It is a curse on me that I can't seem to force FWTools executables to
use my own DLLs in preference to ones in C:\windows\system32.
Best regards,
Piero Cavalieri wrote:
> Hi all,
> I have upgraded FWtools from 1.0.7 to 1.3.7.
> When trying to run OpenEV from Windows menu I have the following error:
> The ordinal *2821* could not be located in the dynamic link library
> *LIBEAY32*.*dll*.
> When trying to run from command line I have the following error:
> C:\Programmi\FWTools>openev.bat
> Traceback (most recent call last):
> File "C:\PROGRA~1\FWTools\pymod\openev.py", line 80, in ?
> import gviewapp
> File "C:\PROGRA~1\FWTools\pymod\gviewapp.py", line 139, in ?
> import gtkmissing
> File "C:\PROGRA~1\FWTools\pymod\gtkmissing.py", line 3, in ?
> import _gv
> ImportError: DLL load failed with error code 182
> Could someone tell me what could be happen (maybe *LIBEAY32*.*dll
> *overwritten with wrong version) ?
> Thanks in advance
> Piero
and watch the world go round - Rush | President OSGeo, http://osgeo.org
