Any help appreciated!! - Fwd: 5.0 - use of
qstring_validation_pattern for attribute queries
Mike Saunt
mikesaunt at GMAIL.COM
Fri Sep 28 06:54:44 EDT 2007
Hi All
I sent this out earliler in the week - has anyone used a 'qstring' in
MapServer 5.0 where the pattern should be able to match any string? I can't
seem to get it to work even though I get messages back such as Failed to
parse expression: Mendip = Mendip msyyparse(): Expression parser error.
parse error msEvalExpression: Expression parser error.
Would there be any examples in the test cases / data etc?
Cheers
Mike
Hi All
I was wondering whether anyone has an example of the METADATA key for
qstring_validation_pattern that is required for v5.0 layers that are to be
attribute queried?
I would like to be able to accept any string (as through my app you can't
inject the values)
I've tried the following qstring_validation_pattern /^[0-9]*$/ and
qstring_validation_pattern '.' but neither seem to match (the first throws a
symbol definition error):
LAYER
NAME Ward
TYPE POLYGON
STATUS OFF
CONNECTIONTYPE OGR
CONNECTION "Overlays\CouncilDemocracy\Ward_Boundaries_2004.TAB"
TOLERANCEUNITS METERS
METADATA
END
CLASS
STYLE
COLOR -1 -1 -1
END
STYLE
OUTLINECOLOR 0 0 0
WIDTH 2
END
END
END
I've also tried as TYPE QUERY...
Any help would be greatly appreciated
Cheers
Mike
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070928/4426f3de/attachment.html
