Changing map file parameters via URL
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Sun Sep 30 23:41:31 EDT 2007
Hi John: Modifying the filter like that is not allowed in 5.0 for security reasons. There
are workarounds. The easiest is simply to use runtime subs. The filter would like like:
FILTER "iso_2digit = '%myval%'"
then you'd do a ...&myval=CA&... The only issue would be that you wouldn't have a default
value this way, but could set myval=US to do just that.
You should also consider setting a validation pattern for the myval variable in the web object
metadata. E.g.:
WEB
METADATA
myval_validation_pattern '^[A-Z]{2}$'
END
END
This would further restrict the passed value to a 2 character string.
Steve
>>> John Cartwright <John.C.Cartwright at NOAA.GOV> 09/27/07 7:28 PM >>>
Hello All,
I'm trying to modify an existing layer on a per request basis using
mapserver CGI. I have a postgis layer defined as:
LAYER
NAME US
FILTER "iso_2digit = 'US'"
END
and I am trying to modify the FILTER element by including:
map_US_FILTER=iso_2digit='CA'
in the request. Can someone point out what I'm doing wrong? (This is
version 5.0 on MacOSX 10.4)
Thanks!
--john
