[mapserver-users] Unable to access Grid Object (GridObject) via
C#MapScript interface (related to bug 1980)
brian.hulbert at linquest.com
Tue Apr 1 18:52:15 EDT 2008
I have a MAP file that contains a layer for displaying graticule (see
below). However, after the first refresh, the labelformat for my grid
object is lost. This was noted in bug 1980
<http://trac.osgeo.org/mapserver/ticket/1980> . I cannot find a workaround
for this bug by traversing the layer->class object hierarchy and trying to
set a labelformat for the GridObject.
Can the label format be reset via the mapscript_csharp dll interface? If
not, is drawing the graticule lines better accomplished via a shape file?
Even if I need to do both a equirectangular and orthographic projections?
Ref: I am using MapScript 5.0.2 and calling it from C# using MS VS 2005
LAYER
NAME "grid"
METADATA
"DESCRIPTION" "Grid"
END
TYPE LINE
STATUS ON
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
CLASS
NAME "Graticule"
COLOR 192 192 192
LABEL
COLOR 255 255 0
FONT arial
TYPE truetype
SIZE 8
POSITION AUTO #ur
PARTIALS FALSE
BUFFER 5
END
END
GRID
LABELFORMAT "%g°" # dec degrees with symbol
MAXARCS 10
MAXINTERVAL 10
MAXSUBDIVIDE 64
END
END # Layer
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080402/d88e40a5/GWAVA_2TEXT.htm
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080402/d88e40a5/3Part.obj
AdmID:701ACEF74791402FA61791610BE043D2
