[mapserver-users] 500 Internal server error
P Kishor
punk.kish at gmail.com
Wed Apr 2 08:11:35 EDT 2008
On 11/2/07, Ignacio J. Moratiel <imoratiel at tecnosylva.com> wrote:
> Apache error log :
> [Tue Apr 01 14:12:30 2008] [error] [client 80.59.*.*]
> /srv/www/cgi-bin/mapserv: symbol lookup error: /srv/www/cgi-bin/mapserv:
> undefined symbol: gdImageJpegCtx, referer:
> http://www.dipuleon.es/atica/portada_turcia.html
> [Tue Apr 01 14:12:30 2008] [error] [client 80.59.*.*] Premature end of
> script headers: mapserv, referer:
> I tried PNG, it works fine, but JPEG returns 500 error
there you go. You solved it yourself (with a little nudge from me and
a big nudge from your error log).
If you insist on using Jpeg, recompile the program correctly (it seems
that your mapserv does claim that it supports jpeg, but I don't know
what is going on there), else use PNGs or GIFs. Should keep you busy
for a while.
Good luck.
> P Kishor escribió:
> On 4/2/08, Ignacio J. Moratiel <imoratiel at tecnosylva.com> wrote:
> I've compiled and installed mapserver on Suse 10.0 and mapserv file is on
> cgi-bin directory. When I try to run the scripts I get a 500 internal error
> message.
> I can read on this page
> http://mapserver.gis.umn.edu/docs/howto/compiling_on_unix
> 500 Internal server error: This is a fairly generic error message. All it
> basically tells you is that the web server was unsuccessful in running the
> program. You will have to consult the web server's error log to find out
> more, and may need to enlist the help of your webmaster/system administrator
> well, what does your Apache error_log say? Did you check the logfile?
> Mapserver creates a 0 bytes image in temp directory, and returns 500 error,
> so I think Apache is running program but mapserver fails.
> mapserv -v returns:
> MapServer version 4.8.4 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> Is there any way to check mapserv script is compiled ok? Should I check
> other things?
> Thanks for your help
