[MAPSERVER-USERS] how mapserver handles different datum
projections
DNC
dncarreira at gmail.com
Sat Apr 5 17:55:39 EDT 2008
Frank,
Is there a way to add the towgs84 definition in the map file?
When I try that MS gives an error:
msProcessProjection(): Projection library error. no options found in
'init' file
The projection definition is this:
'init=epsg:27492 towgs84=-223.237,110.193,36.649'
Thanks,
Duarte
Frank Warmerdam-2 wrote:
> DNC wrote:
>> Hi all.
>> Can anyone clarify how mapserver handles different datum in the map
>> projection and in the layers projection when serving a wms service?
>> Does MS apply datum transformations? If not, can it be done somehow
>> without
>> converting the layers?
>> In my case I'm working with vector data, and have defined a map
>> projection
>> using "init=epsg:code" syntax. Then at the layer level I use the same
>> syntax
>> to declare the projection the data is in.
>> And finally I want my WMS service to be published in 3 different datum
>> and
>> for that I advertise several epsg codes in the "wms_srs" metadata entry.
>> I'm noticing a shift in images produced by MS that indicate a datum shift
>> is
>> not being applied. What can be done?
> Duarte,
> In general MapServer will apply a datum shift if you have datum
> definitions
> for the source and destination coordinate system. But often the
> definitions
> in the EPSG init file lack datum shift info and so nothing is done.
> So, start by examining the PROJ.4 definitions in the "epsg" init file and
> see if they have +towgs84= or +nadgrids directives. You might also want
> to
> skim the material in the PROJ.4 FAQ about datums.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
> mapserver-users at lists.osgeo.org
View this message in context: http://www.nabble.com/how-mapserver-handles-different-datum-projections-tp16517601p16518435.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
