[mapserver-users] MapServer + Fusion
Nolte, Tim
Tim.Nolte at ipcswirelessinc.com
Mon Apr 7 08:35:55 EDT 2008
Greg,
I'm assuming you're talking about MapGuide Fusion. I'm also looking to move to Fusion from Chameleon. Here is the info I got when I posed this question to the MapGuide list.
Hope this gets you started in the right direction.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Paul Spencer
Sent: Wednesday, March 05, 2008 10:04 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Fusion Framework & UMN MapServer
Hi Tim,
it can be but there is currently no official open source version of
fusion that works with mapserver. We are currently in the process of
moving fusion to osgeo servers at which time a community can grow
around both mapguide and mapserver back-ends.
That being said, you can edit config.json in fusion to set the
appropriate values for your mapserver install and set up a map in the
application definition using MapServer as the type and give a MapFile
path in the extension ... something like:
<MapSet xsi:type="MapSetType">
<MapGroup id="gmap" xsi:type="MapType">
<Map xsi:type="MapLayerType">
<Type>MapServer</Type>
<SingleTile>true</SingleTile>
<Extension>
<MapFile>/ms4w/apps/gmap/htdocs/gmap75.map</MapFile>
</Extension>
</Map>
</MapGroup>
</MapSet>
and then change the MapWidget tag to point to the id of the map group
(gmap in the above example) and it should all just work. Note that
mapserver support requires that you have php_mapscript and a valid
session.save_path set up in php.ini
Also, the name of the php_mapscript module is hardcoded in fusion/
MapServer/php/Common.php so if you want something other than:
$szPHPMapScriptModule = 'php_mapscript.'.PHP_SHLIB_SUFFIX;
you will need to manually change it there for now.
Cheers
Paul
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS: 616-706-2438
Fax: 616-554-6484
Web: www.ipcswirelessinc.com
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Gregorio Muñoz Avila
Sent: Monday, April 07, 2008 6:09 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] MapServer + Fusion
Does anyone know how to integrate Fusion in Mapserver?
