[mapserver-users] compiling on windows
Florin A.
pianosnake at gmail.com
Mon Apr 7 16:54:12 EDT 2008
Hi Frank,
I forgot the rest....
C:\projects\regex-0.12\regex.c(4079) : warning C4018: '>=' : signed/unsigned
mismatch
C:\projects\regex-0.12\regex.c(4110) : warning C4018: '<=' : signed/unsigned
mismatch
C:\projects\regex-0.12\regex.c(4123) : warning C4018: '<=' : signed/unsigned
mismatch
C:\projects\regex-0.12\regex.c(4293) : warning C4018: '>=' : signed/unsigned
mismatch
C:\projects\regex-0.12\regex.c(3771) : warning C4101: 'destination' :
unreferenced local variable
C:\projects\regex-0.12\regex.c(3918) : warning C4101: 'destination' :
C:\projects\regex-0.12\regex.c(3971) : warning C4101: 'destination' :
C:\projects\regex-0.12\regex.c(4110) : warning C4101: 'destination' :
C:\projects\regex-0.12\regex.c(4123) : warning C4101: 'destination' :
C:\projects\regex-0.12\regex.c(4876) : warning C4996: 'errcode' was declared
deprecated
C:\Program Files\Microsoft Visual Studio 8\VC\INCLUDE\crtdefs.h(506)
: see declaration of 'errcode'
Message: 'This name was supported during some Whidbey pre-releases.
Instead, use the standard name errno_t.'
C:\projects\regex-0.12\regex.c(4876) : error C2081: 'preg' : name in formal
parameter list illegal
C:\projects\regex-0.12\regex.c(4876) : error C2081: 'errbuf' : name in
formal parameter list illegal
C:\projects\regex-0.12\regex.c(4876) : error C2081: 'errbuf_size' : name in
C:\projects\regex-0.12\regex.c(4877) : error C2055: expected formal
parameter list, not a type list
C:\projects\regex-0.12\regex.c(4877) : error C2082: redefinition of formal
parameter 'errcode'
C:\projects\regex-0.12\regex.c(4885) : warning C4996: 'errcode' was declared
deprecated
C:\projects\regex-0.12\regex.c(4885) : error C2059: syntax error : 'type'
C:\projects\regex-0.12\regex.c(4893) : error C2275: 'errcode' : illegal use
of this type as an expression
C:\projects\regex-0.12\regex.c(4910) : warning C4996: 'strcpy' was declared
deprecated
Message: 'This function or variable may be unsafe. Consider using
strcpy_s instead. To disable deprecation, use _CRT_SECURE_NO_DEPRE
CATE. See online help for details.'
NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
8\VC\BIN\cl.EXE"' : return code '0x2'
Stop.
On Mon, Apr 7, 2008 at 2:03 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Florin A. wrote:
> > Hello,
> > I'm trying to compile MapServer on Windows Server 2003. I followed all
> > the instructions on
> > http://mapserver.gis.umn.edu/docs/howto/win32_compiling and I'm stuck
> > with regex errors. The errors are the same as this post
> > http://www.mail-archive.com/mapserver-users@lists.umn.edu/msg15996.html
> > I'm compiling with nmake from Microsoft Visual Studio 8
> > I also tried compiling with the buildkit from
> > http://download.osgeo.org/buildkit/ and got the same errors.
> > regex.c
> > C:\projects\regex-0.12\regex.c(768) : warning C4018: '<' :
> > signed/unsigned mismatch
> > C:\projects\regex-0.12\regex.c(1953) : warning C4018: '>' :
> > I tried the correction mentioned for the regex.c file:
> > //extern void printchar ();
> > void printchar( int i ) {}
> > This made no difference. I also tried with the win32 regex distribution
> > from http://people.delphiforums.com/gjc/gnu_regex.exe and again, exactly
> > the same errors.
> > Has anybody else encountered this regex error? Shouldn't nmake work
> > with no problems on the buildkit ?
> Florin,
> The above are just warnings. I would encourage you to just ignore them
> and proceed.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080407/1dccada7/attachment.html
