[MAPSERVER-USERS] CLOSE_CONNECTION=DEFER - Segmentation fault
Dave Fuhry
dfuhry at gmail.com
Mon Apr 7 20:01:11 EDT 2008
Carlos,
I won't be able to look at this until after April 14th. But note
that I posted a third version of my patch which Ivan is using.
(Lesson learned: From now on in Trac, I'm posting a separate file for
every version of a patch). It seems like you're using the latest, but
check to be sure.
If you can send a snippet of the python code you're using, that
might help. I assume you are using CLOSE_CONNECTION=DEFER on the
layer. There is clearly still something wrong with the series of SQL
statements being issued; for one thing, a ROLLBACK followed by BEGIN
should only be issued if the previous statement ended erroneously.
The SELECT * FROM tablename WHILE false LIMIT 0 is normal though;
mapserver needs to know the field names and data types. Pity it can't
infer them from the layer definition; there's probably a good reason
it can't.
Thanks,
Dave Fuhry
On Fri, Mar 28, 2008 at 12:47 PM, Carlos_Molina
<dr.chamberlain at gmail.com> wrote:
> I miss one extra query right here:
> DECLARE mycursor2 BINARY CURSOR FOR SELECT... // getShape(1)
> FETCH ALL in mycursor2
> CLOSE mycursor2
> ROLLBACK
> //////////////////////////////////////////////////////////queryByAttribute///////////////////////////////////////////////////////////////
> ERROR: DECLARE CURSOR may only be used in transaction blocks
> WARNING: there is no transaction in progress
> statement: rollback
> statement: begin
> ERROR: cursor "mycursor" does not exist
> ABORT
> I tried this QueryByAttribute by itself, without the first QueryByRect I
> showed no my last post and it seems to be missing a BEGIN statement for its
> cursor.
> Saludos!
> Carlos_Molina wrote:
> > Dave Fuhry wrote:
> >> Ivan,
> >> p.mapper seems to use the typical php
> >> {map,layer}Obj_queryBy{Point,Rect,etc.} functions. These calls end up
> >> calling the same msPOSTGIS* functions as everything else.
> >> I can't seem to reproduce your problem with a simple testcase
> >> (basically, the attached files). It might help if you can set
> >> log_min_duration_statement = 0 in your postgresql.conf, reproduce the
> >> problem, and send the output from your postgresql log file. It will
> >> show all commands issued to the database, including the BEGIN, and the
> >> DECLARE CURSOR ..., and FETCH for every layer.
> >> I can setup p.mapper if that's necessary to reproduce the problem.
> >> (By the way, I assume you're not using an ancient version of
> >> postgis, in the 0.5 - 0.6 era. There is an alternate codepath for
> >> that, which I have not tested.)
> >> Thanks,
> >> Dave
> > Hello Dave,
> > I've tried first and second version of your patch and both resolved my
> > first issue of many many BEGIN statements being issued by cursors so my
> > application went back to running smoothly. The sad part is that another
> > issued arised from this patch and It's when using python mapscript and the
> > drawQuery call.
> > If i just render my .map file with draw() I get no trouble, but if I open
> > my map file, get a single layer from it, query the layer, open the layer
> > to retrieve results and call drawQuery() afterwards to render everything
> > like I used to do before the patch, I get the following error(I resumed
> > the sql statements):
> > BEGIN
> > DECLARE mycursor BINARY CURSOR FOR SELECT... // queryByPoint
> > CLOSE mycursor
> > SELECT * FROM... "same as above" WHILE false LIMIT 0 // Dont know why this
> > is issued, might be openLayer or just to get the field names of the table
> > WARNING: there is already a transaction in progress
> > BEGIN
> > DECLARE mycursor2 BINARY CURSOR FOR SELECT... // getShape(0)
> > CLOSE mycursor2
> > ROLLBACK
> > BEGIN
> > CLOSE mycursor2
> > ROLLBACK
> > statement: rollback
> > statement: begin
> > ABORT
> > Regards
> > Carlos Molina
> View this message in context: http://www.nabble.com/CLOSE_CONNECTION%3DDEFER----Segmentation-fault-tp15786741p16353907.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
