[mapserver-users] PostGIS data in EPSG:31300 using for Google
Maps overlay
Steven De Vriendt
gisaalter at gmail.com
Tue Apr 8 16:29:20 EDT 2008
Brent,
Maybe quite a basic question, but I'm not used to define my data
syntax as the one you propose.
Can you help me out with the <gid> declaration.
I'm quite confused what to fill in for gid
Do I leave it like it is and just write gid or doi I have
or do I have to define my primary key column (f.i.: tbl_b_cabu_pkey).
For both I get an error message, saying either column OID does not
exist or column tbl_b_cabu_pkey does not exist.
However there are both there...
DATA "new_geom from (select gid, transform(the_geom,4326) as new_geom from
table) as mytable using unique gid using srid=4326"
Thanks for helping out !
On Tue, Apr 8, 2008 at 8:25 PM, Steven De Vriendt <gisaalter at gmail.com> wrote:
> Brent,
> Very, very usefull info. Thanks. I was just about to reprojecting my data :-)
> I thought the SRID table was "constrained" to the geometry and you couldn't
> change it. Seems like that's why the 'virtual' table is there for. Ok,
> well, I'll give
> it a try. Thanks for your input !
> Regards,
> Steven
> On Tue, Apr 8, 2008 at 7:58 PM, Brent Wood <pcreso at pcreso.com> wrote:
> > --- Steven De Vriendt <gisaalter at gmail.com> wrote:
> > > Hi list,
> > > I have some data in PostGIS I wish to overlay in Google Maps using WMS
> > > I'm using the same data in a mapserver application, where EPSG code
> > > 31300 is used.
> > > Now for overlay in Google Maps, 4326 is required.
> > > I have made a copy of my map-file and specified 4326 as projection
> > > system.Yet, non of my data is showing up.
> > > Do I need to reproject my data for this use ? I thought PostGIS was
> > > capable of doing reprojection on the fly ?
> > Hi Steven,
> > Both mapserver & POstGIS can reproject the data on the fly, but they need to be
> > told the input & output projections.
> > As your data is all displayed via mapserver, the instructions either way will
> > be in your mapfile.
> > To reproject using PostGIS, edit the SQL command in your data statement which
> > retrieves the PostGIS data. You need to tell PostGIS to return a virtual table
> > to mapserver, and transform the data to the required projection in this. Edit
> > the data line in the layer something like this:
> > To reproject in mapserver, you need to set the main mapfile projection to
> > EPSG:4326, using, in the global header part of the mapfile:
> > UNITS DD
> > PROJECTION
> > "init=epsg:4326"
> > END
> > In the METADATA section, you'll need to set the output projection for WMS, eg:
> > METADATA
> > "wms_title" "My WMS Server"
> > "wms_srs" "EPSG:4326"
> > END
> > Then in the layer definition, you specify the layer's native projection, so
> > mapserver can reproject from one to the other:
> > LAYER
> > PROJECTION
> > "init=epsg:31300"
> > END
> > END
> > Note that to reproject in PostGIS, Proj.4 support must be compiled into
> > PostGIS, and similarly for mapserver if you do the reprojection there. If you
> > compiled these from source, this is not done by default, & you'll need to run
> > configure with the appropriate flag. If you installed from a package, or on
> > Windows, proj support is generally built in.
> > HTH,
> > Brent Wood
