[MAPSERVER-USERS] PostGIS data in EPSG:31300 using for Google
Maps overlay
Steven De Vriendt
gisaalter at gmail.com
Wed Apr 9 03:47:39 EDT 2008
thanks Carla, although I'm not sure about that last bit. So I have
searched for the epsg parameters of 31300 (Belge Lambert 72), and now
I have to add some parameters ? I'm not sure which parameters I have
to add/adjust..
<31300> +proj=lcc +lat_1=49.83333333333334 +lat_2=51.16666666666666
+lat_0=90 +lon_0=4.356939722222222 +x_0=150000.01256 +y_0=5400088.4378
+ellps=intl +units=m +no_defs no_defs <>
Thanks
Steven
On Wed, Apr 9, 2008 at 9:04 AM, cfb <carla.fernandezb at gmail.com> wrote:
> Hi Steven,
> I had the same problems, my data were in EPSG:23030 but when I wanted to
> overlay my WMS in Google Earth, even If I'd included EPSG:4326 in the
> wms_srs list, It showed a difference between my map and Google. So, first of
> all, you must include the 4326 in your wms_srs list (in the header and in
> the layers), then you must set EPSG:4326 as your projection object in the
> header, leaving the layers projections as 31300, and then you must look at
> the epsg file in the PROJ library (\\ms4w\proj\nad), because probably your
> EPSG code (31300) asn't all the parameters needed to reproject correctly the
> data...
> Look something like +towgs84, and try to find some parameter that help
> MapServer to reproject better the data...like this you won't have to
> reproject your original data
> Regards
> gisaalter wrote:
> > Hi list,
> > I have some data in PostGIS I wish to overlay in Google Maps using WMS
> > I'm using the same data in a mapserver application, where EPSG code
> > 31300 is used.
> > Now for overlay in Google Maps, 4326 is required.
> > I have made a copy of my map-file and specified 4326 as projection
> > system.Yet, non of my data is showing up.
> > Do I need to reproject my data for this use ? I thought PostGIS was
> > capable of doing reprojection on the fly ?
> > Can someone with some more experience help me out ?
> > Thanks
> > Steven
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> View this message in context: http://www.nabble.com/PostGIS-data-in-EPSG%3A31300-using-for-Google-Maps-overlay-tp16562400p16580808.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
