[mapserver-users] help: load a static map
marco.sileri at virgilio.it
Wed Apr 9 11:47:16 EDT 2008
Hi
I'm a student and I’m starting my first application of MapServer
with my own data following the tutorial and I already have the
following problem.
I have a very simple shape data in
geographic/WGS84 and also UTM/WGS84 format; I have picked the extension
using ARCGIS and I have tried a static visualization of my map as it is
shown in the first example of the tutorial.
MAP
IMAGETYPE PNG
# EXTENT -97.348976 41.619778 -82.122902 49.385620 #geo
states
EXTENT 12.238976 41.619778 13.122902 49.385620
#geo rieti
# EXTENT 73306.04 -295414.39 1501200.05
614634.59 #laea states
# EXTENT 280000.0 4660000.0 376000.0
4735000.0 #UTM/WGS84 rieti
SIZE 1000 1000
SHAPEPATH "/ms4w/apps/marco/data"
IMAGECOLOR 255 255 255
# Start of LAYER DEFINITIONS
LAYER # States polygon
layer begins here
NAME comuni
DATA comuni_rieti_ll
STATUS OFF
TYPE POLYGON
CLASS
NAME
"comuni"
STYLE
COLOR 232 232 232
OUTLINECOLOR
32 32 32
END
END
END # States polygon layer ends here
I
have tried the following things:
- load my data using the geographic
coordinates (and corresponding extension);
UTM/WGS84 coordinates (and corresponding extension);
- read the data
through the html-page or entering the URL (http://localhost/cgi-
bin/mapserv.exe?map=/ms4w/apps/marco/htdocs/example1-1.
map&layer=states&mode=map)
I always don’t have any error, but I only
see the window in which the data should be visualised.
It’s looks
like the extension is wrong, but I have checked my shape with ArcGis
and also with Ogrinfo ….
INFO: Open of `comuni_rieti_ll.shp'
using driver `ESRI Shapefile' successful.
Layer name: comuni_rieti_ll
Geometry: Polygon
Feature Count: 73
Extent: (12.436251, 42.089346) -
(13.409627, 42.740986)
Layer SRS WKT:
GEOGCS["GCS_WGS_1984",
DATUM
["WGS_1984",
SPHEROID["WGS_1984",6378137,298.257223563]],
PRIMEM["Greenwich",0],
UNIT["Degree",0.0174532925199433]]
AREA:
Real (15.3)
PERIMETER: Real (15.3)
COD_AMM: Integer (9.0)
COMUNE:
String (35.0)
PROVINCIA: String (20.0)
CS_15: Integer (2.0)
COD_REG:
Integer (3.0)
COD_PRO: Integer (3.0)
COD_COM: Integer (3.0)
What can
be wrong and what other can be done to solve the problem?
Can
anybody, please, help me?
Bye Marco
