[mapserver-users] ms4w mapserver 5.0 can't display raster image.
Delfos, Jacob
Jacob.Delfos at maunsell.com
Sun Apr 13 23:53:41 EDT 2008
It may be worth trying to untar your image. I suspect mapserver *may*
not be able to do this on the fly.
Regards,
Jacob
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
> ptang83 at yahoo.com
> Sent: 14 April 2008 11:41
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] ms4w mapserver 5.0 can't display
> raster image.
> I used Mapserver + Openlayers + Postgis. I can load shp data
> to postgis and display it without any problem. However,
> somehow I am not able to display any raster map even without
> using postgis. I only see a blank rectangular on my web
> browzer. I wonder whether there is a bug or something I did
> wrong. Thanks in advance..
> I have downloaded ms4w Mapserver and has the following config.
> # Apache 2.2.8
> # PHP 5.2.5
> # mapserv 5.0.2 at /cgi-bin/mapserv.exe
> LOG files show nothing wrong:
> Sun Apr 13 21:57:14
> 2008,12804,127.0.0.1,nitelti020l,3,-0.000000 -90.000000
> 180.000000 90.000000,-1.000000 -1.000000,,normal execution
> Sun Apr 13 21:57:14
> 2008,14076,127.0.0.1,nitelti020l,3,-180.000000 -90.000000
> MAP file:
> # Map file created from QGIS project file C:/Program
> Files/Quantum GIS/nitelti020l.qgs
> # Edit this file to customize for your map interface
> MAP
> NAME nitelti020l
> # Map image size
> SIZE 600 600
> UNITS dd
> EXTENT -6086744.000000 -5878356.737659 4278894.138000 7580130.593659
> PROJECTION
> # 'proj=longlat'
> # 'ellps=WGS84'
> # 'datum=WGS84'
> # 'no_defs'
> "init=epsg:4326"
> END
> # Background color for the map canvas -- change as desired
> IMAGECOLOR 192 192 192
> IMAGEQUALITY 95
> IMAGETYPE jpeg
> OUTPUTFORMAT
> NAME jpeg
> DRIVER 'GD/JPEG'
> MIMETYPE 'image/jpeg'
> #IMAGEMODE PC256
> EXTENSION 'jpeg'
> END
> # Legend
> LEGEND
> IMAGECOLOR 255 255 255
> STATUS ON
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> END
> # Web interface definition. Only the template parameter
> # is required to display a map. See MapServer documentation
> WEB
> # Set IMAGEPATH to the path where MapServer should
> # write its output.
> IMAGEPATH '/tmp/'
> # Set IMAGEURL to the url that points to IMAGEPATH
> # as defined in your web server configuration
> IMAGEURL '/tmp/'
> # WMS server settings
> METADATA
> 'wms_title' 'nitelti020l'
> 'wms_onlineresource'
> 'http://localhost/cgi-bin/mapserv?map=wms.map&'
> 'wms_srs' 'EPSG:4326'
> END
> #Scale range at which web interface will operate
> # Template and header/footer settings
> # Only the template parameter is required to display a
> END
> WEB
> LOG "c:\tmp\mapserv.log"
> END
> LAYER
> NAME 'nitelti020l'
> TYPE RASTER
> DATA 'C:\oatdir\nitelti020l.tar\nitelti020l.tif'
> METADATA
> END
> STATUS DEFAULT
> TRANSPARENCY 100
> PROJECTION
> # 'proj=longlat'
> # 'ellps=WGS84'
> # 'datum=WGS84'
> # 'no_defs'
> "init=epsg:4326"
> END
> END
> END
> Raster date download
> http://edcftp.cr.usgs.gov/pub/data/nationalatlas/nitelti020l.tar.gz
> simple open layer code
> <html xmlns="http://www.w3.org/1999/xhtml">
> <head>
> <style type="text/css">
> #map {
> width: 800px;
> height: 475px;
> border: 1px solid black;
> </style>
> <script
> src="http://openlayers.org/dev/lib/OpenLayers.js"></script>
> <script type="text/javascript">
> var map, layer;
> function init(){
> map = new OpenLayers.Map( 'map' );
> layer = new OpenLayers.Layer.MapServer( "OpenLayers WMS",
> "http://localhost/cgi-bin/mapserv.exe",
> {map: 'C:/Program Files/ms4w/Apache/htdocs/nitelti020l.map'} );
> map.addLayer(layer);
> map.zoomToMaxExtent();
> </script>
> </head>
> <body onload="init()">
> <div id="map"></div>
> </body>
> </html>
> __________________________________________________
> Do You Yahoo!?
> Tired of spam? Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
This email and any attachments are intended solely for the named recipient and are confidential. The copying or distribution of them or any information they contain by anyone other than the named recipient is prohibited. If you have received this document in error, please notify the sender and delete all copies from your computer system and destroy all hard copies. It is the recipient's responsibility to check this email and any attachments to this email for viruses before use.
