[mapserver-users] zoom extent
Carlo Pelliconi
c.pelliconi at sis-ter.it
Mon Apr 14 02:20:52 EDT 2008
I think you should try strarting with mapserver basic, not javascript.
Mapserver CGI documentation (for functions) here:
http://mapserver.gis.umn.edu/docs/reference/cgi/controls
Then, for the template (i.e. the html which embeds the map):
http://mapserver.gis.umn.edu/docs/reference/templatereference/templatereference/view
I've never used javascript for functions such as zoom in, because
mapserver itself has them already defined.
Good work.
Carlo
john tse ha scritto:
> Hi,Guys
> I'm currently doing a volunteer project and i need to get a zoom to
> button to work.
> This is the code i have right now
> <html>
> <body>
> <head>
> <script type = "text/javascript">
> // zoom to Region
> function GoRegion() {
> // alert(document.mapserv.mapzoomarea.value);
> document.mapserv.target="";
> document.mapserv.mode.value="browse";
> document.mapserv.imgext.value =
> document.mapserv.submit();
> </script>
> </head>
> <select name="mapzoomarea" onChange="GoRegion();">
> <option>Zoom to Region</option>
> <option>------------------------</option>
> <option value="5457203 487104 5451873 482304">Reserve 2</option>
> <option value="5435308 491431 5434498 490403">Reserve 4</option>
> <option value="5425919 541,907 5502970 444168">Musqueam Statement
> Of Intent</option>
> <option value="5435189 475830 5457751 504449">Richmond
> Boundary</option>
> <option value="5448859 481843 5463269 500122">Vancouver Boundary
> </option>
> <option value="5432692 482228 5457268 515426">North Arm Fraser
> River </option>
> </select>
> </body>
> </html>
> it doesn't do anything, and i have no idea what's wrong with it, any
> help will be much appreciated.
> thanx
> mapserver-users at lists.osgeo.org
ing. Carlo Pelliconi
SIS.TER S.p.A.
www.sis-ter.it
via Mentana, 10
40026 Imola (BO) Italy
ATTENZIONE!
Questo documento è indirizzato esclusivamente al destinatario. Tutte le
informazioni ivi contenute, compresi eventuali allegati, sono soggette
a riservatezza secondo i termini del D.Lgs. 196/2003 in materia di
"privacy" e ne è proibita l'utilizzazione da parte di altri soggetti. Si ricorda che la diffusione l'utilizzo e/o la conservazione dei dati ricevuti per errore costituisce violazione di carattere penale ai sensi dell'art. 616 Codice penale (Violazione, sottrazione e soppressione di corrispondenza). Se avesse ricevuto per errore questo messaggio, La preghiamo cortesemente di contattare il mittente al più presto e di cancellare il messaggio subito dopo. Grazie.
ATTENTION!
This message is being sent from Sis.Ter S.p.A. and may contain information which is confidential or privileged. If you are not the intended recipient, please advise the sender immediately by reply e-mail and delete this message and any attachments without retaining a copy. Any unauthorized use of the content of this message is a breach of your duty to respect the confidentiality of the correspondence between other persons and can expose the responsible party to civil and/or criminal penalties (D.Lgs. 196/2003 "Tutela della privacy" e art. 616 Codice penale "Violazione, sottrazione e soppressione di corrispondenza"), and may constitute a more serious offence. Thanks.
ACHTUNG!
Dieses Dokument ist ausschließlich dem Empfänger vorbehalten. Die darin enthaltenen Informationen, auch jene in etwaigen Anlagen, gelten im Sinne des Dekrets Nr. 196/2003 in Sachen "Privacy" als streng vertraulich und dürfen von anderen Personen nicht verwende werden. Wer diese Mitteilung irrtümlicherweise erhält ist gebeten uns umgehend zu informieren und anschließend die Mitteilung zu vernichten. Vielen Dank.
