[mapserver-users] mapserver 5 configure with options does not
work (fedora 7/8)
Ningchuan Xiao
xiao.37 at osu.edu
Wed Apr 16 09:38:40 EDT 2008
Nahum and Frank -
Many thanks to your helpful suggestions! Now it works like a charm...
Ningchuan
On Tue, Apr 15, 2008 at 9:48 PM, Nahum Castro <pedro1_72 at yahoo.com> wrote:
> --- Frank Warmerdam <warmerdam at pobox.com> escribió:
> > Ningchuan Xiao wrote:
> > > Dear All,
> > > I was wondering if anyone could please help me
> > solve this problem. I
> > > compiled MapServer 5.0.2 on Fedora 7 and 8. I
> > installed all required
> > > libraries/packages. If I configure MapServer
> > without any options (i.e.,
> > > just use ./configure), the resulting file mapserv
> > works fine if I copy
> > > it to the cgi-bin folder.
> > > However, if I configure it using any other options
> > (such as --with-proj,
> > > with proj4 successfully installed), I can compile
> > MapServer with no
> > > problem and can run mapserv -v. However, if I copy
> > it to the cgi-bin
> > > folder, it will not work. All I get is a blank
> > page in the web browser
> > > with no error messages.
> > Ningchuan,
> > I would guess this is because the extra options have
> > shared libraries in
> > places that aren't searched under apache. For
> > instance, if libproj.so
> > is installed in /usr/local/lib and you haven't
> > managed that properly via
> > ldconfig or LD_LIBRARY_PATH.
> > Best regards,
> create a file named mapserver.conf in
> /etc/ld.so.conf.d/ and add the next lines:
> /path/to/proj4/libs
> /path/to/gdal/libs
> /path/to/geos/libs
> mine is
> /usr/local/lib
> /usr/local/pgsql/lib
> because i compiled from source postgresql+postgis,
> gdal, proj4 and geos
> If you will use php-mapscript install
> #yum -y install php-devel
> Use ./configure --help
> for more parameters
> Nahum.
> Nahum Castro
> Leon, Guanajuato, Mexico
> http://www.leon-linux.com
> e-mail: pedro1_72 [en] yahoo [punto] com
> ____________________________________________________________________________________
> ¡Capacidad ilimitada de almacenamiento en tu correo!
> No te preocupes más por el espacio de tu cuenta con Correo Yahoo!:
> http://correo.yahoo.com.mx/
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080416/6722e1ed/attachment.html
