[mapserver-users] Any Fedora fc8 64 bit mapserver users out there?
[SEC=UNCLASSIFIED]
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Apr 16 23:59:40 EDT 2008
Thank you for the suggestion.
As it turns out, they loaded Debian Etch 64bit and I got the full stack
of tools loaded and built with only one problem, not with the OS/HW. So
I don't know it the sysadmin check other stuff on the box or switched
hardware or not. Frank W posited that the problem was a mismatch of
header files and libraries around the librx. I thought it might be more
global because of the GD SEGV I ran into, but that followed me to
Debian. It turns out the that GD SEGV is a mapserver bug and the dev
team is chasing that. So, I'm inclined to agree with Frank's assessment
at this point.
Regardless, I'm happy and things are running smoothly again and the
client is happy. Life is good!
Thanks,
-Steve
Tim Bowden wrote:
> Try running memtest before anything else. That may isolate the problem
> and save a heap of work.
> Regards,
> Tim
> On Wed, 2008-04-16 at 10:32 -0500, Stephen Woodbridge wrote:
>> Hi Antti,
>> I have heard back from 3-4 other users of 64bit Fedora and none of them
>> are having problems like I had. The symptoms I was having are so basic
>> that I am beginning to think that they may be hardware memory? related.
>> We are wiping that system and installing Debian Etch 64bit on it and
>> seeing how that plays. I have been running Debian Sarge on a 64bit dual
>> Xeon server for 2 years and have had no problems with 64bit apps or with
>> compiling and building any of the GIS stack that I use. If we still have
>> problems, then I think we can be assured it is hardware. If we don't.
>> I'm not sure what that tells us, but I will probably stick with Debian
>> on this box because I have work to do on it and don't have time to
>> trouble issues like this.
>> I hope this helps,
>> -Steve
>> Roppola, Antti - BRS wrote:
>>> Hi all,
>>> This is pretty timely as we are scoping out new servers and up 'til
>>> now I have conciously avoided 64 bit deployments. The abundance of
>>> 64 bit platforms seems to have made 64 bit less boutique and less risky.
>>> Antti
>>> -----Original Message-----
>>> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Nahum Castro
>>> Sent: Wednesday, 16 April 2008 11:54 AM
>>> To: Stephen Woodbridge; mapserver-users
>>> Subject: Re: [mapserver-users] Any Fedora fc8 64 bit mapserver users out there?
>>> --- Stephen Woodbridge <woodbri at swoodbridge.com>
>>> escribió:
>>>> Hi,
>>>> If you are a Fedora fc8 64 bit mapserver user (or close to that), can
>>>> you please contact me off list. I'm having mapserver runtime issues
>>>> and just need to compare notes and see what your experiences have
>>>> been.
>>>> Many thanks in advance,
>>>> -Steve Woodbridge
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>> I have mapserver installed on fc8 x86_64 with no problems.
>>> I compilled all this software gd, proj4, geos, postgresql, postgis, gdal and grass, then mapserver with php-mapscript and ogc services.
>>> All other software was from fedora repositories.
>>> I have 2 installations one with intel and the other with AMD both fc8 64.
>>> Nahum.
>>> Nahum Castro
>>> Leon, Guanajuato, Mexico
>>> http://www.leon-linux.com
>>> e-mail: pedro1_72 [en] yahoo [punto] com
>>> ____________________________________________________________________________________
>>> ¡Capacidad ilimitada de almacenamiento en tu correo!
>>> No te preocupes más por el espacio de tu cuenta con Correo Yahoo!:
>>> http://correo.yahoo.com.mx/
>>> ------IMPORTANT - This message has been issued by The Department of Agriculture, Fisheries and Forestry (DAFF). The information transmitted is for the use of the intended recipient only and may contain confidential and/or legally privileged material. It is your responsibility to check any attachments for viruses and defects before opening or sending them on.
>>> Any reproduction, publication, communication, re-transmission, disclosure, dissemination or other use of the information contained in this e-mail by persons or entities other than the intended recipient is prohibited. The taking of any action in reliance upon this information by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error please notify the sender and delete all copies of this transmission together with any attachments. If you have received this e-mail as part of a valid mailing list and no longer want to receive a message such as this one advise the sender by return e-mail accordingly. Only e-mail correspondence which includes this footer, has been authorised by DAFF
