[mapserver-users] WMS cascading
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Thu Apr 17 05:03:44 EDT 2008
When you cascade WMS services the LAYER is defining the remote service. The result of using "wms_srs" "EPSG:23033" in the nasa layer metadata means that your Mapserver is using EPSG:23033 when sending requests to wms.jpl.nasa.gov. That is not what you want to do.
Use EPSG:4326 at layer level. The output projections you want to have are described at MAP level WEB - METADATA section, that is the place to insert EPSG:23033. At least this is how I understand the how-to documents "WMS clients with Mapserver" and "WMS servers with Mapserver".
Regards,
-Jukka Rahkonen-
Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Luca Casagrande
Lähetetty: 17. huhtikuuta 2008 2:14
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] WMS cascading
Hello everybody,
I am trying to serve, with my wms server, a layer coming from NASA WMS. The source projection is 4326 and I need to reproject to 23033; inside the metada I put the wms_srs value, but it's not working..I just just a white image. Any idea?
Thanks
Luca
LAYER
NAME "nasa"
TYPE RASTER
STATUS ON
CONNECTION "http://wms.jpl.nasa.gov/wms.cgi?"
CONNECTIONTYPE WMS
PROJECTION
"init=epsg:4326"
END
METADATA
"DESCRIPTION" "JPL Global Mosaic (WMS)"
"wms_name" "global_mosaic_base"
"wms_style" "visual"
"wms_server_version" "1.1.1"
"wms_format" "image/jpeg"
"ows_title" "jpl_wms_global_mosaic"
END
END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080417/bcaf6275/attachment-0001.html
