[mapserver-users] zoom extent
Carlo Pelliconi
c.pelliconi at sis-ter.it
Fri Apr 18 02:23:35 EDT 2008
Template example (but other demo on the web are still very useful for
basic commands):
I have a div which must contain something created by Mapserver, so I use
a particular CGI variable and Mapserver constructs that element (the
legend, the reference map, ...) Use square brackets [ ] for defining the
cgi-variables.
<div>
[cgi-variable]
</div>
or if you want to view the actual scale
<input name="scale" value="[scale]" />
Mapserver itself puts the real actual scale value in the value attribute
of the input.
Hope this helps
Bye, Carlo
john tse ha scritto:
> thanks for the reply, however, i've been playing around with it the
> last few days and still no luck for a customized zoom button. It would
> be most useful if anyone can actually show me a sample script of how
> to put something similar together so that i can learn from it. I don't
> get how the template fits with the CGI.
> On Sun, Apr 13, 2008 at 11:20 PM, Carlo Pelliconi
> <c.pelliconi at sis-ter.it <mailto:c.pelliconi at sis-ter.it>> wrote:
> I think you should try strarting with mapserver basic, not javascript.
> Mapserver CGI documentation (for functions) here:
> http://mapserver.gis.umn.edu/docs/reference/cgi/controls
> Then, for the template (i.e. the html which embeds the map):
> http://mapserver.gis.umn.edu/docs/reference/templatereference/templatereference/view
> I've never used javascript for functions such as zoom in, because
> mapserver itself has them already defined.
> Good work.
> Carlo
> Hi,Guys
> I'm currently doing a volunteer project and i need to get a
> zoom to button to work.
> This is the code i have right now
> <html>
> <body>
> <head>
> <script type = "text/javascript">
> // zoom to Region
> function GoRegion() {
> // alert(document.mapserv.mapzoomarea.value);
> document.mapserv.target="";
> document.mapserv.mode.value="browse";
> document.mapserv.imgext.value =
> document.mapserv.submit();
> </script>
> </head>
> <select name="mapzoomarea" onChange="GoRegion();">
> <option>Zoom to Region</option>
> <option>------------------------</option>
> <option value="5457203 487104 5451873 482304">Reserve
> 2</option>
> <option value="5435308 491431 5434498 490403">Reserve
> 4</option>
> <option value="5425919 541,907 5502970 444168">Musqueam
> Statement Of Intent</option>
> <option value="5435189 475830 5457751 504449">Richmond
> Boundary</option>
> <option value="5448859 481843 5463269 500122">Vancouver
> Boundary </option>
> <option value="5432692 482228 5457268 515426">North Arm
> Fraser River </option>
> </select>
> </body>
> </html>
> it doesn't do anything, and i have no idea what's wrong with
> it, any help will be much appreciated.
> thanx
> mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
> ing. Carlo Pelliconi
> SIS.TER S.p.A.
> www.sis-ter.it <http://www.sis-ter.it>
> via Mentana, 10
> 40026 Imola (BO) Italy
> ATTENZIONE!
> Questo documento è indirizzato esclusivamente al destinatario.
> Tutte le
> informazioni ivi contenute, compresi eventuali allegati, sono soggette
> a riservatezza secondo i termini del D.Lgs. 196/2003 in materia di
> "privacy" e ne è proibita l'utilizzazione da parte di altri
> soggetti. Si ricorda che la diffusione l'utilizzo e/o la
> conservazione dei dati ricevuti per errore costituisce violazione
> di carattere penale ai sensi dell'art. 616 Codice penale
> (Violazione, sottrazione e soppressione di corrispondenza). Se
> avesse ricevuto per errore questo messaggio, La preghiamo
> cortesemente di contattare il mittente al più presto e di
> cancellare il messaggio subito dopo. Grazie.
> ATTENTION!
> This message is being sent from Sis.Ter S.p.A. and may contain
> information which is confidential or privileged. If you are not
> the intended recipient, please advise the sender immediately by
> reply e-mail and delete this message and any attachments without
> retaining a copy. Any unauthorized use of the content of this
> message is a breach of your duty to respect the confidentiality of
> the correspondence between other persons and can expose the
> responsible party to civil and/or criminal penalties (D.Lgs.
> 196/2003 "Tutela della privacy" e art. 616 Codice penale
> "Violazione, sottrazione e soppressione di corrispondenza"), and
> may constitute a more serious offence. Thanks.
> ACHTUNG!
> Dieses Dokument ist ausschließlich dem Empfänger vorbehalten. Die
> darin enthaltenen Informationen, auch jene in etwaigen Anlagen,
> gelten im Sinne des Dekrets Nr. 196/2003 in Sachen "Privacy" als
> streng vertraulich und dürfen von anderen Personen nicht verwende
> werden. Wer diese Mitteilung irrtümlicherweise erhält ist gebeten
> uns umgehend zu informieren und anschließend die Mitteilung zu
> vernichten. Vielen Dank.
SIS.TER S.p.A.
www.sis-ter.it
via Mentana, 10
tel +39 0542 364034
fax +39 0542 612130
ATTENZIONE!
Questo documento è indirizzato esclusivamente al destinatario. Tutte le
"privacy" e ne è proibita l'utilizzazione da parte di altri soggetti. Si ricorda che la diffusione l'utilizzo e/o la conservazione dei dati ricevuti per errore costituisce violazione di carattere penale ai sensi dell'art. 616 Codice penale (Violazione, sottrazione e soppressione di corrispondenza). Se avesse ricevuto per errore questo messaggio, La preghiamo cortesemente di contattare il mittente al più presto e di cancellare il messaggio subito dopo. Grazie.
ATTENTION!
This message is being sent from Sis.Ter S.p.A. and may contain information which is confidential or privileged. If you are not the intended recipient, please advise the sender immediately by reply e-mail and delete this message and any attachments without retaining a copy. Any unauthorized use of the content of this message is a breach of your duty to respect the confidentiality of the correspondence between other persons and can expose the responsible party to civil and/or criminal penalties (D.Lgs. 196/2003 "Tutela della privacy" e art. 616 Codice penale "Violazione, sottrazione e soppressione di corrispondenza"), and may constitute a more serious offence. Thanks.
ACHTUNG!
Dieses Dokument ist ausschließlich dem Empfänger vorbehalten. Die darin enthaltenen Informationen, auch jene in etwaigen Anlagen, gelten im Sinne des Dekrets Nr. 196/2003 in Sachen "Privacy" als streng vertraulich und dürfen von anderen Personen nicht verwende werden. Wer diese Mitteilung irrtümlicherweise erhält ist gebeten uns umgehend zu informieren und anschließend die Mitteilung zu vernichten. Vielen Dank.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080418/83c50bad/attachment-0001.html
