[mapserver-users] How to tile a large TIF image?
Stefan Schwarzer
stefan.schwarzer at grid.unep.ch
Fri Apr 18 09:02:56 EDT 2008
Thanks a lot for these details. That should be added to the existing
documents!
But unfortunately I still get a "Segmentation fault" message...
Stef
> Stefan,
> I don't think you can specify 10'', you need something in pixels.
> But the command is also probably not what you really need to do.
> More likely, you should be doing the following:
> gdal_translate -co "TILED=YES" gebco/bathymetry.tif gebco/
> bathmetry_tiled.tif
> This will create a single tif file that has an internal block size
> of 256x256 - you can think of this as having broken your tif up into
> 256x256 tiles but keeps them all within the same file. This is
> equivalent to breaking the tif up into individual files, creating a
> shapefile that has rectangles for each individual files' extent, and
> using that as a tile index in mapserver.
> Next, you want to do this:
> gdaladdo gebco/bathymetry.tif 2 4 6 8 16
> this will pre-compute smaller versions of the tif image called
> overviews at 1/2, 1/4 1/6 1/8 and 1/16 of the original size of the
> tif - this makes it much more efficient for gdal to return exactly
> what mapserver is asking for at any given scale. Depending on the
> range of scales that you need to display your raster image at, you
> can add more overview levels (or take some away).
> With this two commands, you can make your rasters much more
> efficient for mapserver and probably avoid the need to split them up
> into many files.
> It does make the file somewhat larger. If you are working with very
> large files ( > 4GB ) then you may run into some problems with tiff
> and may need to investigate another format or a compressed format
> like ECW or MrSID (both requiring commercial licenses I believe).
> There are also some built in compression schemes for tiffs in gdal
> which you can apply when running gdal_translate (see http://www.gdal.org/frmt_gtiff.html
> for creation options), for instance:
> gdal_translate -co "TILED=YES" -co "COMPRESS=JPEG" -co
> "JPEG_QUALITY=80" gebco/bathymetry.tif gebco/bathmetry_tiled.tif
> would compress the tif using JPEG compression (lossy) set to 80%
> (low compression, small loss).
> Cheers
> Paul
> On 18-Apr-08, at 5:47 AM, Stefan Schwarzer wrote:
>> Thanks for the info.
>> Did it like this:
>> Library/Frameworks/GDAL.framework/Versions/1.5/Programs/
>> gdal_translate -outsize 10'' 10'' -co TILED=YES gebco/
>> bathymetry.tif gebco/bathymetry_tiled.tif
>> But get the message: "Segmentation fault"
>> Anything that I did wrong? Or should do differently?
>> Thanks for a hint,
>> Stef
>>> Hi,
>>> Gdal_translate program has options for you:
>>> c:\FWTools>gdal_translate
>>> Usage: gdal_translate [--help-general]
>>> [-ot {Byte/Int16/UInt16/UInt32/Int32/Float32/Float64/
>>> CInt16/CInt32/CFloat32/CFloat64}] [-strict]
>>> [-of format] [-b band] [-outsize xsize[%] ysize[%]]
>>> [-scale [src_min src_max [dst_min dst_max]]]
>>> [-srcwin xoff yoff xsize ysize] [-projwin ulx uly lrx lry]
>>> [-a_srs srs_def] [-a_ullr ulx uly lrx lry] [-a_nodata value]
>>> [-gcp pixel line easting northing [elevation]]*
>>> [-mo "META-TAG=VALUE"]* [-quiet] [-sds]
>>> [-co "NAME=VALUE"]*
>>> src_dataset dst_dataset
>>> By playing with -srcwin or possibly with -outsize and -projwin you
>>> should be able to split your image as you wish. Read more from
>>> http://gdal.org/gdal_translate.html
>>> -Jukka Rahkonen-
>>> Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org
>>> ] Puolesta Stefan Schwarzer
>>> Lähetetty: 18. huhtikuuta 2008 12:05
>>> Vastaanottaja: mapserver-users at lists.osgeo.org
>>> Aihe: [mapserver-users] How to tile a large TIF image?
>>> Hi there,
>>> I would like to use instead of single large tif image smaller
>>> tiles. Although I am well aware of mapserver's and gdal's
>>> possibilities to create the shapes for it, I first need to "split"
>>> the large tif into 20 or 50 or 100 tiles.
>>> Can anyone give me a hint with what kind of software this is
>>> possible?
>>> There is an ArcGIS script, but it doesn't work on my machine ( http://arcscripts.esri.com/details.asp?dbid=13978
>>> Thanks for any hints,
>>> Stef
>>> ____________________________________________________________________
>>> Stefan Schwarzer
>>> Lean Back and Relax - Enjoy some Nature Photography
>>> http://photoblog.la-famille-schwarzer.de
>>> Appetite for Global Data? UNEP GEO Data Portal:
>>> http://geodata.grid.unep.ch
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Paul Spencer
> Chief Technology Officer
> DM Solutions Group Inc
> http://www.dmsolutions.ca/
