[mapserver-users] One layer filled with 3 colors
Steve Lime
Steve.Lime at dnr.state.mn.us
Tue Apr 22 18:41:56 EDT 2008
If in your database you transformed the various values of zona into colors (e.g. stored the color in a column called zona_color)
then you could do:
LAYER
DATA "the_geom from car_marccata"
CLASS
STYLE
COLOR [zona_color]
END
END
END
You'd need to set those up ahead of time, or at least create a color lookup table and do the join in the DATA statement.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-259-5473
>>> On 4/22/2008 at 10:38 AM, in message
<9c2e09570804220838h2d9075c8q1379c764d90eee0e at mail.gmail.com>, "Emilio Ponce"
<yosoycore at gmail.com> wrote:
> This code takes me now to a new one question:
> Is there a way to assign colours dynamically? I'm wondering if
> mapserver is able to detect the different options of the column
> 'zona', and then use random palette colours to represent these
> automatically, without having to set COLOR for each one manually. It
> can be useful because every column has different options.
> Thank you guys,
> 2008/4/22 Emilio Ponce <yosoycore at gmail.com>:
>> Thanks Stephen!
>> I've found the solution with your idea, is very similar to your code:
>> LAYER
>> CLASSITEM "zona"
>> CLASS
>> EXPRESSION "FORA"
>> COLOR 143 81 8
>> END
>> CLASS
>> EXPRESSION "MAR"
>> COLOR 0 154 239
>> END
>> CLASS
>> EXPRESSION "CATA"
>> COLOR 223 223 223
>> END
>> END
>> Regards,
>> 2008/4/22 Stephen Woodbridge <woodbri at swoodbridge.com>:
>> > Emilio Ponce wrote:
>> > > Hi everyone,
>> > > I'm trying to paint one layer with 3 different colors, depending on
>> > > one field called 'zona' that is a column of the table stored at a
>> > > postGIS database. I'm doing this in the layer:
>> > > STATUS DEFAULT
>> > > CONNECTIONTYPE postgis
>> > > CONNECTION "host=**** dbname=**** user=**** password=****
>> > port=****'"
>> > > FILTER "zona='FORA'"
>> > > CLASS
>> > > COLOR 143 81 8
>> > > END
>> > > FILTER "zona='MAR'"
>> > > CLASS
>> > > COLOR 0 154 239
>> > > END
>> > > FILTER "zona='CATA'"
>> > > CLASS
>> > > COLOR 223 223 223
>> > > END
>> > > It doesn't works.. I've tried different strategies but I haven't found
>> > > the problem yet. Does anyone knows what's wrong?
>> > > Thanks!
>> > Try this:
>> > STATUS DEFAULT
>> > CONNECTION "host=**** dbname=**** user=**** assword=****
>> > port=****'"
>> > CLASSITEM "zona"
>> > CLASS
>> > EXPRESSION ([zona] = 'FORA')
>> > COLOR 143 81 8
>> > END
>> > CLASS
>> > EXPRESSION ([zona] = 'MAR')
>> > COLOR 0 154 239
>> > END
>> > CLASS
>> > EXPRESSION ([zona] = 'CATA')
>> > COLOR 223 223 223
>> > END
>> Emilio
