[mapserver-users] AGG Anti-alias & VECTOR sybmol
thomas bonfort
thomas.bonfort at gmail.com
Wed Apr 23 01:29:37 EDT 2008
by the way, seeing your output I don't think that you're using agg.
have you correctly set IMAGETYPE AGGA in your mapfile (or use
format=AGGA in your url if using mapserv)
thomas
On Wed, Apr 23, 2008 at 5:02 AM, Jackey Cheung <cheung.jackey at gmail.com> wrote:
> Greetings!
> I've generated a map: http://maps.mapking.com/eg.png
> with these:
> OUTPUTFORMAT
> NAME "AGGA"
> DRIVER "AGG/PNG"
> IMAGEMODE RGBA
> TRANSPARENT ON
> EXTENSION "png"
> FORMATOPTION "INTERLACE=OFF"
> END
> CLASS
> MAXSCALEDENOM 5000000
> MINSCALEDENOM 500000
> STYLE
> WIDTH 4
> COLOR 50 50 50
> END
> STYLE
> SYMBOL "rail_line"
> SIZE 3
> COLOR 250 250 250
> END
> END
> SYMBOL
> NAME "rail_line"
> TYPE ELLIPSE
> POINTS
> 1 1
> END
> STYLE
> 8 4 8
> END
> # GAP 100
> FILLED TRUE
> #ANTIALIAS TRUE
> END
> As you can see in the image, the everything are smooth except the railway.
> All line and polygon layers are drawn with "simple" styles without the use
> of SYMBOL. Only the railway lines are drawn with a VECTOR symbol.
> Does AGG's anti-alias works with symbols? If not, any work around?
> mapserver-users at lists.osgeo.org
