[mapserver-users] Large scale PDF output on Windows
bartvde at osgis.nl
bartvde at osgis.nl
Wed Apr 23 07:44:46 EDT 2008
There is MAXSIZE for this on the MAP object:
MAXSIZE [integer]
Sets the maximum size of the map image. This will override the default
value. For example, setting this to 2048 means that you can have up to 2048
pixels in both dimensions (i.e. max of 2048x2048).
Wrt resource issues, we have seen Masperver fail (internal server errors)
on such big images depending on the dataset. For instance with aerial
photography (ECW) I've run into resource issues in the past. Sometimes the
limit was a bit below 10.000 pixels, sometimes 15.000 went fine. It all
depends how lucky you are :-)
Best regards,
Bart
On Wed, 23 Apr 2008 07:38:24 -0400, Christopher Schmidt
<crschmidt at metacarta.com> wrote:
> On Wed, Apr 23, 2008 at 01:30:12PM +0200, Kristian Thy wrote:
>> I'm trying to generate pdf output from mapserver to be printed in A3
>> format at 600 dpi (which is not negotiable). We're currently using the
>> 5.0.2 binary from ms4w, which has a limitation of 2048 px square. I have
>> calculated I need 9921 by 7015 px output.
>> Before I prostrate myself before the altar and make sacrifices to the
>> gods of compiling-mapserver-on-windows, can anybody confirm that output
>> of this size is indeed possible? The only thing I can find through
>> Google is this post from Ed McNierney - four and a half years old:
> You don't need to recompile anymore. You can change this in a mapfile
> setting. (I don't know what it is, I'm sure that someone else will tell
> you: but wanted to make sure you got stopped before you started
> compiling.)
> And yes, output of that size is possible. I believe that when I was
> talking to pagameba, he was talking about rendering on the order of 50
> x 50 256 px tiles -- about 10000 by 10000 or more. At that point, you
> may be limited by memory limits of some kind, depending on your
> rendering rules... but someone else can comment on that as well.
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0309/msg00417.html
>> \\kristian
>> ... et nemo ex vobis interrogat me: »Quo vadis?«
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Christopher Schmidt
> MetaCarta
