[mapserver-users] AGG Anti-alias & VECTOR sybmol
Jackey Cheung
cheung.jackey at gmail.com
Thu Apr 24 03:36:18 EDT 2008
It works! Thank you very much! Even better, this is much simpler than using
VECTOR or ELLIPSE symbols!
On Wed, Apr 23, 2008 at 1:29 PM, thomas bonfort <thomas.bonfort at gmail.com>
wrote:
> by the way, seeing your output I don't think that you're using agg.
> have you correctly set IMAGETYPE AGGA in your mapfile (or use
> format=AGGA in your url if using mapserv)
> thomas
> On Wed, Apr 23, 2008 at 5:02 AM, Jackey Cheung <cheung.jackey at gmail.com>
> wrote:
> > Greetings!
> > I've generated a map: http://maps.mapking.com/eg.png
> > with these:
> > OUTPUTFORMAT
> > NAME "AGGA"
> > DRIVER "AGG/PNG"
> > IMAGEMODE RGBA
> > TRANSPARENT ON
> > EXTENSION "png"
> > FORMATOPTION "INTERLACE=OFF"
> > END
> > CLASS
> > MAXSCALEDENOM 5000000
> > MINSCALEDENOM 500000
> > STYLE
> > WIDTH 4
> > COLOR 50 50 50
> > END
> > STYLE
> > SYMBOL "rail_line"
> > SIZE 3
> > COLOR 250 250 250
> > END
> > END
> > SYMBOL
> > NAME "rail_line"
> > TYPE ELLIPSE
> > POINTS
> > 1 1
> > END
> > STYLE
> > 8 4 8
> > END
> > # GAP 100
> > FILLED TRUE
> > #ANTIALIAS TRUE
> > END
> > As you can see in the image, the everything are smooth except the
> railway.
> > All line and polygon layers are drawn with "simple" styles without the
> use
> > of SYMBOL. Only the railway lines are drawn with a VECTOR symbol.
> > Does AGG's anti-alias works with symbols? If not, any work around?
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080424/02f65c8a/attachment-0001.html
