Fwd: [MAPSERVER-USERS] Fwd: CLOSE_CONNECTION=DEFER - Segmentation
fault
Ivan Mincik
ivan.mincik at gmail.com
Fri Apr 25 13:36:54 EDT 2008
Thanks a lot Dave,
according to tests on my local machine there are no other problems with v6
patch. Next week I will try it on production system.
Ivan
On Sunday 20 April 2008 21:26, you wrote:
> Ivan,
> BTW there is a new version of the mappostgis.c patch, v6 at
> http://trac.osgeo.org/mapserver/ticket/2497 , which further cleans up
> the code (but doesn't add any new enhancements). If you get a chance
> to test it and find any problems, let me know (and CC the
> mapserver-users list on reply).
> Thanks,
> Dave
> On Sat, Mar 22, 2008 at 10:33 AM, Ivan Mincik <ivan.mincik at gmail.com> wrote:
> > Hi Dave and others,
> > >Here is the report about testing second version of
> > >ms_postgis_begin_to_connect.diff (03/20/08 18:35:00) in p.mapper with
> > >PROCESSING "CLOSE_CONNECTION=DEFER.
> > >I have started browsing the map, using Obj_queryBy functions, turning
> > > on and off different layers. Application was working smoothly without
> > > any error or warning in the log.
> > >THE PROBLEM will occur when I stop working in pmapper for a while and
> > > try to continue browsing. (in the log it is between 09:41:44 and -
> > > 09:46:05 and 09:50:03 - 09:52:30) . After these pauses I had to
> > > restart browser to get p.mapper working again, but in 20 percent still
> > > application is still freezing.
> > >Same problems can be reproduced every new pmapper session.
> > I have solved this problem with php session settings so this last
> > problem was probably on php/p.mapper site. Now the logs are clear.
> > Tomorrow I will test it with more users then one.
> > Ivan
> > >Maybe I can try some session configurations in apache or postgres. Any
> > >advises?
> > >PostgreSQL log is here:
> > >http://projects.gpsmapy.sk/logs/ms_postgis_begin_to_connect_version2.lo
> > >g
> > >Dave, thanks a lot for Your work
> > >Ivan
> > >On Friday 21 March 2008 18:12, you wrote:
> > > Ivan,
> > > Yes, I updated the patch on the bug report page
> > > http://trac.osgeo.org/mapserver/ticket/2497 around the time I sent
> > > those emails yesterday. Download it, make sure it differs from the
> > > ms_postgis_fix_trans_state.diff you're currently using, `svn revert
> > > mappostgis.c`, and try it with the new patch.
> > > Sorry that was not clear.
> > > Thanks,
> > > Dave
> > > On Fri, Mar 21, 2008 at 4:59 AM, Ivan Mincik <ivan.mincik at gmail.com>
wrote:
> > > > On Thursday 20 March 2008 23:46, you wrote:
> > > > > Ivan,
> > > > > Try the new version of the patch, just posted. I had
> > > > > accidentally removed a necessary query in msPOSTGISLayerGetShape.
> > > > > My tests which now include getShape() are working (with or
> > > > > without PROCESSING "CLOSE_CONNECTION=DEFER").
> > > > Hi Dave,
> > > > I have allready tried patch ms_postgis_fix_trans_state.diff and I
> > > > have posted the report. Or is there any updated version of
> > > > ms_postgis_fix_trans_state.diff?
> > > > I am sure that I have updated php_mapscript.so.
> > > > For sure I include my report of testing
> > > > ms_postgis_fix_trans_state.diff:
> > > > I have applied new patch ms_postgis_fix_trans_state.diff to
> > > > mapserver-5.0.2 sources from debian unstable and recompiled new
> > > > debian package and install.
> > > > Then I have:
> > > > 1. restarted apache
> > > > 2. restarted postgresql-8.1
> > > > 3. restarted browser (deleted cache)
> > > > And started this test with p.mapper 3.2 application:
> > > > 1. Browsing the map (moving, zooming out, zooming in, adding some
> > > > more layers) 2. Using identify
> > > > ({map,layer}Obj_queryBy{Point,Rect,etc.}) - ERROR: cursor "mycursor2
> > > > immediately
> > > > 3. Browsing the map (moving, zooming out, zooming in)
> > > > 4. Using identify ({map,layer}Obj_queryBy{Point,Rect,etc.}) -
> > > > ERROR: cursor "mycursor2 immediately
> > > > Result:
> > > > With this patch it is not possible to do neither a singel object
> > > > query. (with older patch it was possible few times).
> > > > After "ERROR: cursor "mycursor2" does not exist" it is possible to
> > > > continue browsing the map again and object query fill finish with
> > > > same result as above.
> > > > {map,layer}Obj_queryBy{Point,Rect,etc.} function is not
> > > > working also when #PROCESSING "CLOSE_CONNECTION=DEFER" is
> > > > disabled. So identify object is not working at all.
> > > > log is here:
> > > > http://projects.gpsmapy.sk/logs/ms_postgis_fix_trans_state_patch.log
